I have a 2014 C7 base auto. Recently it has been acting crazy randomly. One minute it’s fine, the next it has hardly no power, no back up camera when in reverse, active exhaust will not work, you cannot tell what gear you are in (does not display the P, R, N, D) shifts super rough and throws the CEL with another weird light at the top of the cluster that almost looks like a wrench.
CEL is U0101- Permanent: Lost Communication with transmission control module. DTC Severity 2 of 3: this fault may pose damage to components and should be repaired as soon as possible.
P26C8: Chassis Control Module Requested MIL Illumination
P050D Permanent: Cold Start Rough Idle
im thinking it is a loose or corroded ground, but I don’t know where they all are located. As mentioned, it will drive fine, flip out like this for 5-10 mins, then back to acting fine. Any ideas???
With the “U” code sounds like a possible communication issue…I don’t know what mechanical or electrical abilities you possess but if it is a communication issues 999 out of a 1000 repair shops or dealerships would have no idea and how to even begin to diagnose this…how old is your battery ??…I always start a diagnosis with a battery check…you will need a factory level scan tool to see if you can communicate with the TCM when you are having issues…unfortunately it’s not a blown fuse.
Battery is brand new now. Issues still come and go randomly.
I just didn’t know if a ground could be loose or dirty to cause this. It’s weird it runs find sometimes, and sometimes it acts completely crazy.
If you think it’s a ground issue the ground for the TCM which unfortunately is internal to the transmission is G401 and is in the left rear wheel well area.
I would go back to the battery connections. Make sure they are straight and tight. Look up the torque specs for the nuts.
Did you break the little black wire?
No need to worry about the P26C8...it is an informational DTC only...read the NOTE below.
Diagnostic Aids
Communication codes, U-codes, as well as powertrain codes, P-codes, set in the chassis control module will cause the chassis control module to request DTC P26C8 to be set in the ECM.
So you’re saying I cannot access this ground or is just need to remove the wheel and fender well trim to access it?
I will check them all again, the little black wire seemed find but I will also double check it again.
Diagnostic Aids
These G401 grounds that are also on the C5 and C6 are usually on the frame rail…you can look there…BTW, the odd numbered grounds are on the left side of the car and G4XX are in the back…G1XX are in the engine bay.
thank you so much for the help! I will crawl around the drivers side and try and locate all the grounds to clean them and make sure they’re tight.
I wouldn’t waste your time cleaning all these grounds…concentrate on the ground that may be causing your issue…they should be clean and not just tight…are you using a code reader ??
and you think it’s the G-401 ground? Yeah I have the Innova 5610 scanner.
The wrench symbol usually means you have scheduled maintenance or a Powertrain or Transmission issue…my motto is “test don’t guess” so I can’t say for sure what your issue is…below are all the various circuits on G401…your NPP exhaust is one of those grounds…the “Prindle” as we call it may be related to the TCM no communication…I think the Innova should be able to read TCM codes so when it starts going haywire see if you can read “live data” in the TCM or that you can communicate with it…look at the other circuits on G401 and see if they too are affected…it may be shifting rough because of the VSS (vehicle speed sensor)…the car won’t shift right if the ECM does no the cars speed.
This may be a power side and not a ground side issue…I’d clean and tighten all of your connections on the battery fuse block and the auxiliary also !!
Man I really appreciate the documents! I can’t wait to get to work on the car. I will update you on what I find. I will probably tear into it tomorrow or the next day after work.
