Shocks
Old Mar 29, 2025 | 12:02 AM
CADZO6's Avatar
CADZO6
7th Gear
Default Shocks
I was told today that the front shocks need to be replaced with less than 16k miles on the car. Is this normal and do I replace them with OEM shocks?
Thanks!
Old Mar 29, 2025 | 12:09 AM
This thread is better placed in the C7 Tech section. Moving the thread there.
Old Mar 29, 2025 | 11:29 AM
kodpkd's Avatar
kodpkd
Who told you? I assume the dealer. Can you visually check then yourself? Maybe the oil leaked out of them.
Old Mar 29, 2025 | 11:36 AM
CADZO6's Avatar
CADZO6
7th Gear
Default Shocks
A local automotive repair shop.
Old Mar 29, 2025 | 11:42 AM
kodpkd's Avatar
kodpkd
Old Mar 29, 2025 | 11:45 AM
kodpkd's Avatar
kodpkd
You can see the base of the shocks and check for oil.
Old Mar 29, 2025 | 10:19 PM
kkupec02's Avatar
kkupec02
Welcome!!
Old Mar 29, 2025 | 10:33 PM
^&right's Avatar
^&right
Some leakage is normal with mag ride.
Old Apr 1, 2025 | 01:00 PM
sir5574's Avatar
sir5574
Mine had 3 out of the 4 leaking pretty bad, I just replaced all 4 last weekend. What questions do you have?
Old Apr 1, 2025 | 02:31 PM
rtv900's Avatar
rtv900
I had two of four leaking last year, did all four in my garage in a few hours. Only had 20k miles total but the car was 9 years old
as it's a 2015 Z06
it's the age that got them not the mileage
Old May 20, 2025 | 10:37 AM
TheGreenLanternC7's Avatar
TheGreenLanternC7
What shocks you are using?
Am looking for new shocks, but I want them a bit stiffer by default, if you can recommend a set? Tnx
Old May 22, 2025 | 11:32 AM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
If your mag ride shock leak, its time to put new ones on, the leak will only get wares. The oil will get on your brake pads & rotors & the lower control arm.
Old May 30, 2025 | 05:46 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Your profile doesn't tell us anything about your car. Sometimes the screen name helps, and sometimes not. Please fill in some info.
If your car has the Mag Side shocks, they have been very prone to leakage. At about 2 yrs/20k miles, our 2017 Z51 had all four Mag Ride shocks replaced under warranty.
Now at 7 years/62k miles, the replacements are doing fine. Attached is a document explaining how to judge condition.
To Shocks
