Excessive Cranking?
Old Apr 30, 2025 | 03:37 PM
Laguna Blu's Avatar
Laguna Blu
Default Excessive Cranking?
I notice that on certain occasions, mostly in the morning after sitting overnight the car takes a little while to fire up. We have 91 octane fuel out here and so far, I've used a bottle of Techron Fuel system cleaner in the last tank and for this tank I poured STP 100 Octane in with the fuel. I'm used to 93 octane back east. Not that I expect that those things make a difference, but do you think it's a fuel pump issue or maybe a crank sensor? It's not a ton of cranks but more than it should to fire up. Thanks in advance.
Old Apr 30, 2025 | 03:41 PM
Macleod52's Avatar
Macleod52
Could be a low/weak battery. How old is it?
Old Apr 30, 2025 | 04:10 PM
Laguna Blu's Avatar
Laguna Blu
I would doubt that only because it's been serviced by the dealer throughout its life (according to Carfax), and recently I had to go to an independent mechanic because my parking brake got stuck in the locked position, and because this particular shop had no history with the car, in addition to flashing the e-brake boost module they gave me a report on the entire mechanical condition of the car and everything all was new or like new. Sorry for the run-on banter.
Old Apr 30, 2025 | 04:31 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Could be a crank or cam sensor...without a labscope this will not be able to be diagnosed accurately.
Old Apr 30, 2025 | 04:40 PM
BELVIN20's Avatar
BELVIN20
From GM the following are expected start times:
Above 50F may take up to 1.5 seconds
From 14F-49F up to 2.5 seconds
Unless the ambient temperature is -4F or colder it should not take 5 seconds.
Old Apr 30, 2025 | 05:03 PM
bearone2's Avatar
bearone2
unless carfax shows a batt replacement, check date code on batt!!
Old Apr 30, 2025 | 05:16 PM
C5 Diag's Avatar
C5 Diag
Where did you get these numbers from ??...I have Factory Service Info and I know this is not in there...if the ECT sensor is working correctly even at 0 degrees the car should start right up.
Old Apr 30, 2025 | 06:22 PM
Dcasole's Avatar
Dcasole
I can assure you , u don't need a scope , it will instantly pop a code .... ask me how I know .....
Dave
Old Apr 30, 2025 | 06:24 PM
Dcasole's Avatar
Dcasole
agreed , long crank under certain conditions is normal
Dave
Old Apr 30, 2025 | 08:47 PM
BELVIN20's Avatar
BELVIN20
Link to GM bulletin on crank times.
https://www.corvetteactioncenter.com...2018-1351.html
Old Apr 30, 2025 | 09:24 PM
Dcasole's Avatar
Dcasole
If the crank or cam position sensor fails the ECM will revert to a default setting which results in a long crank ..... but it only took a few starts before my ECM popped as CEL light and a crank position sensor code . The sensor is cheap but it's behind the starter so it can be a pain in the a$$ to install especially since I have headers . After install there is a reset procedure that you have to run . Once I did the reset car started instantly.... just as it always had
Dave
Old May 10, 2025 | 04:43 PM
Bill Dearborn's Avatar
Bill Dearborn
My 2015 Z06 cranks quickly at times and cranks longer at other times. Either way, when the engine fires, it snaps to life. GM bulletins have indicated long cranks will happen and my car has had intermittent long cranks since I purchased it on 11/30/2015 (almost 10 years). In other words it is normal.
Bill
Old May 11, 2025 | 09:28 PM
Sayfoo's Avatar
Sayfoo
LT1 DI engine? Look at post #3
https://www.corvetteforum.com/forums...ine-noise.html
Old May 14, 2025 | 03:29 PM
cbrider73's Avatar
cbrider73
Mine does the same after a long sit. I have DI BMWs and you can hear the low pressure pump prime as you open the car door. The Corvette does not do that - the low pressure pump switches on as soon as you switch the ignition on.
I verified this (7MT car) by holding the start button down without pressing in the clutch. That turns the system on and I can hear the low pressure pump do its thing. The car will fire right up with no long crank every time I do that procedure no matter how long it has been sitting. It will not long crank in any temperature if it has been running recently. That long crank is from the fuel system priming. BMW figured it out and pre-primes the system before you ever touch the start button.
I am sure you can test this with an AT car by not pushing the brake pedal while holding the start button down.
Old May 14, 2025 | 03:34 PM
Zjoe6's Avatar
Zjoe6
My experience is same as Bill on two different CZ 7's. It's normal.
To Excessive Cranking?
