Tire life
Old Jul 9, 2025 | 09:58 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by aklim
I can afford to buy a tuxedo but would I wear it to work if my job is a lube tech? Sure, you can but why waste your money? Many of the Corvette owners might not be punching it any more than a lot of F250 trucks with a clean and shiny bed are working the truck. I don't believe I had to promise to run my car to the max when I bought it. If I am running it to the 140 HP level, why buy 450 HP level tires just because I can? I don't feel I have to waste my money just to fit in with the boys' club.
Give me a break. The Corvette isn't anything special besides in the owner's imagination. It's just another mass production higher HP car. It even shares parts across the brand. Back in the day when I did autocross, I see old Datsuns, Ford Taurus and even the occasional minivan and trucks. Bunch of Mustangs and F-bodies. Tell you what I didn't see. More than 2 Corvettes on any given track day unless they were trailered.
Fortunately, things have changed.
In our area (Northern Illinois/Southern Wisconsin), there will be about 6-8 NCCC autocross weekends each season, with typically 30-50 drivers each weekend.
95% of the cars will be Corvettes, and 90% of those are driven to/from the event by their owner. Only few people will trailer the car or tow a small trailer with track tires.
Old Jul 9, 2025 | 11:16 PM
aklim's Avatar
aklim
The autocrosses I was in was NOT an NCCC event . I haven't been to one for a long time but have they changed much since then?
Old Jul 10, 2025 | 12:47 AM
RacerRik's Avatar
RacerRik
How about giving the rest of us break. If you do not think the Corvette is special, why are you wasting so much of your time on this forum? Almost 27,000 posts and you have been here for 21 years!
What other "mass produced" cars perform like the Corvette for pickup truck money? We typically have 6 to 8 Corvettes show up to our autocrosses and they do quite well.
Old Jul 10, 2025 | 09:35 AM
Gearhead Jim
St. Jude Donor '13
I've been doing autocross for over 25 years, started out doing SCCA events and after getting our 2001 C5 I switched to NCCC.
The big difference I noticed is that SCCA events usually are run on shorter and tighter courses, which give an advantage to the smaller but lower powered cars typically attending. I used to call them "high speed parallel parking".
NCCC tries to run more open courses that allow the Corvette driver to use more of his power.
Neither style is "better" or "worse", they just allow drivers to enjoy the strong points of their particular car.
But we see lots of Corvettes that drove to the event, tape on some numbers, and go out there to exercise the car. My car has collected its share of "cone blood".
Old Jul 10, 2025 | 09:38 AM
aklim's Avatar
aklim
I believe the C7 engines are used in other cars as is the transmission? I get that you might want to feel special but I think we are going to have to step up a whole lot of dollars more to be in the "special" category. A territory I'm not wanting to be in so yes, I'm tapping out. I'm NOT in it for the tradition or whatever non-tangible quality it might have.
I did consider Porsche or BMW but the wife's sudden decision to get rid of "That rickety POS" (the C4) on a Saturday morning didn't give me much time to scope out support for either of those lines.
Old Jul 10, 2025 | 09:51 AM
aklim's Avatar
aklim
Our group did a mix of tight parking lot courses and some at a larger track like Road American and some other place whose name escapes me runs. IMO, it keeps it more even so the groups don't feel like they are at a constant disadvantage. More important, I believe many of the higher HP vehicles did not like the rate their tires were being eaten up on the smaller courses.
Old Jul 11, 2025 | 10:03 AM
speed4tu's Avatar
speed4tu
If the tires aren't cracked or leaking i would 100% keep using them. I am almost confident you aren't racing the car nor driving it extremely spirited on the street. Furthermore you have 3000 miles in 6 years. Why spend over a thousand bucks on another set of tires to sit and rot away? Drive it your 500 miles for the year and rock on.
Old Jul 11, 2025 | 10:42 AM
aklim's Avatar
aklim
That is another option, I guess.
Old Jul 14, 2025 | 03:05 PM
TxLefty's Avatar
TxLefty
IMHO, you are sort of in no-man's land on age. Probably not old enough to just junk based on age. They won't perform as well as a set of new tires. They are probably safe for standard street cruising, but maybe a little too old if you plan on doing any really high-performance driving. So, it's really down to how you plan to drive the car.
