Excessive oil blow by. Procharged
Old May 20, 2025 | 11:08 AM
Creacy22's Avatar
Creacy22
2nd Gear
Default Excessive oil blow by. Procharged
Procharger, oil in the intake, oil on the plugs, oil in the intercooler. Car died will not restart, procharger says add a catch can but it seems like there is more to it. Car is well cared for and has 54000 miles. New to me. Any ideas ?
Old May 20, 2025 | 01:50 PM
C7&7's Avatar
C7&7
Well they're not wrong you should have a catch can or breather, but it sounds like you might of hurt a piston buddy. I suggest doing a compression check asap just for piece of mind.
Old May 22, 2025 | 05:54 PM
Dcasole's Avatar
Dcasole
^^^^^^^^^ THIS^^^^^^^^^^
Dave
Old May 22, 2025 | 07:40 PM
Creacy22's Avatar
Creacy22
2nd Gear
I unhooked the procharger and the car runs like a top, has vacuum at the PCV. I’m going to remove that thing from the car and return it to stock. Sell the procharger.
Old May 22, 2025 | 07:50 PM
Dcasole's Avatar
Dcasole
That won't help if you hurt it ......
Old May 22, 2025 | 07:57 PM
Lowend's Avatar
Lowend
More air into the engine (from a supercharger) = air IN the engine and more blow by.
Assuming the engine isn't hurt, a good PCV inclusive catch can will probably solve your problem for $300 and a couple hours of labor
https://www.improvedracing.com/oil-c...e-engines.html
Or
https://www.eliteengineeringusa.com/...tte-2014-2019/
Old May 23, 2025 | 08:00 AM
Dcasole's Avatar
Dcasole
Or
yeah, that is not going to help with oil on plugs , oil in the intake ....
Heck plenty of people run centris without a catch can , procharger instructions do not even show one
Since he said he took off the charger and it ran fine , it makes makes me believe somebody did not hook up the pvc system correctly and somehow fed boost to the PVC/crank case .......
The only other thing other than incorrectly run pvc hoses that would have allowed boost to get into the crankcase is a busted ring land or a tired motor ( blow by)
I am sure if he just spent some time diagnosing it , it would have been fine
Dave
To Excessive oil blow by. Procharged
