Downstream 02 issue
Old Jun 30, 2025 | 12:39 PM
Thiswork's Avatar
Thiswork
5th Gear
Default Downstream 02 issue
Hello all,
I have a 2015 Stingray that I am having some issues with. I had headers and exhaust installed and all, upstream and downstream, O2 sensors were supposed to be installed due to emissions testing where I live. To make a long drawn out ridiculous story short I got out of the car found my Downstream O2s were missing and still in the factory exhaust. I attempted to install them and the pigtails were too short due to the location of the bungs in the new exhaust. Because I just needed to pass emissions I attempted to lengthen by soldering and splicing without using the proper wire or hear insulation. It worked I passed emissions however 3 miles down the road my connections melted away leaving a bigger problem.
When the wires burned up it shorted everything out. I replaced the 02 sensors and did a proper extension however only one of the two downstream are reading. I have replaced one fuse associated with the 02 sensors I cannot find any others.
help pointing me in the right direction of a solution woukd be appreciated
Old Jun 30, 2025 | 01:08 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The O2 sensors have 4 wires...2 for the sensor that reads the oxygen and the other 2 are for the heater circuit...if you have a scan tool or even a code reader when the engine is cold and the ignition is on you should see 450Mv's which is their bias voltage...what are you reading ??...if you see 450 the wiring is fine...if it is not disconnect the O2 sensor and now read the bias voltage...is it 450 or something else ???
Old Jun 30, 2025 | 01:50 PM
Thiswork's Avatar
Thiswork
5th Gear
It's reading maxed out rich at 1.275v
Old Jun 30, 2025 | 02:39 PM
C5 Diag's Avatar
C5 Diag
The sensor signal wire is most likely shorted to power which is the power feed for the heater circuit...as mentioned disconnect the sensor and still see if it still reads 1.275 volts...that voltage is the max that the ECM can read as it will not read 12 volts......the violet/blue heater power feed is shorted to the violet/blue or violet/green depending which bank it is.
Old Jul 1, 2025 | 03:33 AM
Thiswork's Avatar
Thiswork
5th Gear
If memory serves me... when the O2 was disconnected I was not reading voltage anywhere.
I will check ASAP
Old Jul 1, 2025 | 04:29 AM
Thiswork's Avatar
Thiswork
5th Gear
I just remembered... before the downstreams were installed my live data indicated 1.275 v for both.
are you saying to check the voltage at the plug once O2 is disconnected or to disconnect O2 and view live data ?
Old Jul 1, 2025 | 08:04 AM
C5 Diag's Avatar
C5 Diag
If the O2 sensor is unplugged and you are seeing 1.275 volts with your scan tool the problem is in the wiring…let’s say you are seeing 1.275 volts with it plugged in and now you disconnect the sensor and now you are seeing 450 mv’s the problem is with the sensor and not the wiring.
Old Jul 1, 2025 | 08:06 AM
C5 Diag's Avatar
C5 Diag
In that case you have the signal wire shorted to the heater power wire on both…with no sensor installed seeing 450 mv’s tells me the wiring is good.
Old Jul 5, 2025 | 06:03 AM
Thiswork's Avatar
Thiswork
5th Gear
Thank you, I will check it out and report back.
Just checking continuity to ground should do it?
Old Jul 5, 2025 | 09:35 AM
C5 Diag's Avatar
C5 Diag
No, it most likely is a short to power and not ground so you wouldn’t check continuity to ground…with your scan tool hooked up and reading 1.275 volts remove fuse 36 (Eng O/S Pos fuse 15A) and you should see that voltage disappear…that fuse powers both downstream O2 heater circuits.
To Downstream 02 issue
