battery/gage information
Old Jul 19, 2025 | 04:14 PM
abcd137!'s Avatar
abcd137!
7th Gear
Default battery/gage information
Have a 2018 Grand Sport - battery change - no problems = well the steering gage says low battery - push the button it goes away - need a fix
Old Jul 19, 2025 | 06:39 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Jumping right in I see, I moved you out of introductions... welcome.. and here for help... good luck
Old Jul 19, 2025 | 07:16 PM
BELVIN20's Avatar
BELVIN20
First thing to check is the little black wire on the negative cable, make sure it is hooked up & tight. This wire is a battery sense sire for the computer. Be sure to re check all battery connections, the C7 is famous for what seems like tight connections & they are not tight as they need to be.
Old Jul 19, 2025 | 10:15 PM
kkupec02's Avatar
kkupec02
Welcome!!
Old Jul 19, 2025 | 11:44 PM
RonC7's Avatar
RonC7
Your new battery may not be fully charged. Charge it or go for a 30 min drive. The charge voltage starts at 14+ and drops to around 13 with a fully charged battery. The small black wire on the negative battery clamp is important for proper charging.
If the message is low FOB battery, change it too.
Ron
Old Aug 10, 2025 | 09:08 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
We appreciate you sharing your concerns with the low battery message on the steering gage. If you could fill us in, have you taken it to a dealership for a diagnosis? We want to ensure your 2018 GS is running at its peak performance with no present concerns. Should you need help connecting with your local dealer, please send us an email to socialmedia@gm.com with more surrounding information. Be sure to include the forum title and your forum username in the subject line as well.
Old Nov 5, 2025 | 11:18 AM
abcd137!'s Avatar
abcd137!
7th Gear
Default Jack
checked - I changed the battery and there was no little black wine - there is a plug with wires on it on the neg cable.
Old Nov 5, 2025 | 12:35 PM
Tinkertech's Avatar
Tinkertech
Little black wire on the negative battery cable appears to be missing.
They are often broken during a battery replacement and never caught.
Old Nov 5, 2025 | 02:27 PM
abcd137!'s Avatar
abcd137!
7th Gear
Thanks - just relooked and could not see it - thought maybe under the battery - but - thought it must show itself leaving the battery area- nothing on all sides. Hate to sound dumb but this is a just driving me nuts thing. LOL
Old Nov 5, 2025 | 03:24 PM
Macleod52's Avatar
Macleod52
https://www.corvetteforum.com/forums...ble-clamp.html
You can see the little black wire in post #3. If you don't have that it could cause all sorts of issues. That's where I'd start. Perhaps it got tucked under the carpet or something? Are you the original owner? Did someone else replace the battery? Was the car in an accident?
Old Nov 7, 2025 | 08:10 AM
Tinkertech's Avatar
Tinkertech
Bottom line.
You got to find the black sense wire and reconnect it to the battery negative cable.
To battery/gage information
