C7 won’t turn on
Old Jul 20, 2025 | 01:24 AM
Jermbn's Avatar
Jermbn
Default C7 won’t turn on
I was driving my corvette for maybe 1 hour or so and then when I turn it off and maybe come about 15 minutes later to start it and drive it again, it’ll turn everything on but actually starting the car. Then after another 15-30 minutes it would start. My guess is that I’m overheating the car so it won’t start just yet or something? What could it be.
Old Jul 20, 2025 | 02:09 AM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
If you mean the car won't crank over at first but crank over and start twenty minutes later you probably need a new starter.
Old Jul 20, 2025 | 01:46 PM
Jermbn's Avatar
Jermbn
I replaced the starter in may bcz my starter actually had went out. I drive a manual c7 so not sure if it’s common or not. OH also I always have a rachet on me to unbolt the negative terminal on my battery for 30 secs and reconnect and it actually starts right up just incase I’m in a emergency with the car
Old Jul 21, 2025 | 04:00 AM
JLSuperfly's Avatar
JLSuperfly
Were you stepping on the clutch? jk
Battery maybe?
Old Jul 21, 2025 | 04:01 AM
Jermbn's Avatar
Jermbn
Battery maybe?
is it common to happen? I bought the car in may and the battery says 2/25 on it
Old Jul 23, 2025 | 10:00 AM
jaxcam02's Avatar
jaxcam02
And you don't get any notices on the dash? no check engine light or codes?
To C7 won’t turn on
