opinions wanted
Old Jul 23, 2025 | 01:10 PM
9sec's Avatar
9sec
Default opinions wanted
ok so getting ready to yank the motor for a internal build
parts as follows,
btr stage 2 cam
johnson link bar lifters
btr .660 springs
che trunnion kit
lme vvt delete
dod delete
ati lower damper
katech dry sump oil pump
billet valley tray
at this point with 28k miles on the motor thoughts on replacing all the crank and rod bearings? oil pan has to come off anyway so im literally right there. or leave the bottom end alone its done from the factory low miles and has zero issues
Old Jul 23, 2025 | 02:01 PM
Neorift's Avatar
Neorift
Why are you deleting VVT? Curious because BTR cams are designed with keeping VVT, albeit limited, in mind.
Stock rotating assembly is fine. There are plenty of guys running 800+ HP on it.
Old Jul 23, 2025 | 02:39 PM
9sec's Avatar
9sec
the reason is even with a lockout you can still see 1-2* of cam movement. if im going thru the trouble to degree the cam to the cam manufacturer cam specs allowing it to move defeats the purpose. this can also create extended crank times as the cam moves. some btr cams are designed to run vvt but im going to run a c5r chain ls single bolt sprocket and vvt delete billet cover. the cam I have isnt designed for a vvt setup. this eliminates any chance of cam movement.
im aware of the stock rotating assembly capabilities. what im looking for are opinions on whether I should pull it all apart for new bearings at 28k miles or just leave it alone and concentrate on the top end of the motor
Old Jul 23, 2025 | 02:47 PM
Neorift's Avatar
Neorift
I see. I guess I am just not familiar with the "whys" of people deleting VVT entirely as opposed to keeping it with a limiter installed. What are the cons of running with VVT vs not?
Also, regarding your bearings, I am a big fan of "while I'm in there" replacing wear items, especially if there's an upgrade available.
Old Jul 23, 2025 | 03:19 PM
9sec's Avatar
9sec
as I said extended start issues and not being able to properly degree the cam. as for bearings not looking to upgrade simply install new bearings vs 28k mileage bearings already in the car. if it was a 50-75k mile motor it wouldn't even be a question the bottom end would come out. with 28k im undecided and looking for others opinions.
"while your i9n there" can be a loaded question. replace the rods with carrells? new pistons ? stroke it to a 416 ? the slope can get slippery very quickly. learned that on a 45k$ flat six pcar motor build
Old Jul 23, 2025 | 03:28 PM
Neorift's Avatar
Neorift
It sounds more like you already know what you want and are looking for someone to agree with you. 28,000 miles is a lot more than 0 miles and if 50,000 is your cutoff, are you going to pull the engine out again at that point just to replace bearings? At 75,000? The engine is out, bearings are cheap insurance, why not replace them?
I agree that it is a slippery slope but if you read my post more closely, I said replacing wear items while you're in there.
Old Jul 23, 2025 | 04:00 PM
9sec's Avatar
9sec
I dont disagree. 50k is just a number ive seen motors run 100k with stock internals and beat on all day and new flat plane motors that lasted less than 1000 miles before imploding. ive built motorcycle engines, porches ,m/b and other imports but never a lt4 so thats why im asking. my lean is to leave well enough alone since im not looking at 1000 whp + but rather 750-800 whp. already been down the 4 digit road just want enough power to get me in the 9's and turn a few heads with some cam chop lol
Old Jul 23, 2025 | 09:37 PM
TorchRedRob's Avatar
TorchRedRob
For what it's worth, none of us ZL1 guys are touching the bottom end until past 1000whp. I wouldn't worry with it personally. For my build I'm in the middle of, I had it down to the bare block with just crank, rods, pistons remaining untouched. Everthing else will be replaced. I kept the cam bearings, too.
Old Jul 23, 2025 | 09:42 PM
Laguna Blu's Avatar
Laguna Blu
Wow! Huge difference in bottom end from the C5 days, that's for sure!!
Old Jul 24, 2025 | 10:07 AM
Zjoe6's Avatar
Zjoe6
The magic words for me are "im literally right there". If the parts are relatively cheap I replace them if it's that easy.
Old Jul 24, 2025 | 12:57 PM
TorchRedRob
No doubt. Katech says don't worry about it until over 1000whp, Vengeance says you're good until about 1000-1050whp. With that in mind, I'm "just" doing heads/cam/valvetrain, low side, Goliath, and +70's. Paired with existing 2650, intake, and exhaust, I’m expecting 1000+ on full pump E.
If it fails, I'll pull it back out and go again.
Old Jul 24, 2025 | 02:00 PM
9sec's Avatar
9sec
you aren't far from me so come on up and tear mine apart!! I hate working in this heat we have been car parts over a/c for yrs now.
Old Jul 24, 2025 | 04:52 PM
9sec's Avatar
9sec
looks like a top end build leave the bottom as is . thanks for the dialog it always helps!
Old Jul 27, 2025 | 11:08 AM
9sec's Avatar
9sec
so heres a loaded question!!! does anyone have a cheat sheet of torque values for the motor tear down? ie: head bolts crank pulley bolt cam cover bolts water pump bolts oil pump bolts etc? I really dont want to spend half my vacation looking for torque specs while I put the motor together. (yes im lazy!!). be happy to pay a fee for the cheat sheets
Old Aug 4, 2025 | 11:08 PM
wildhog's Avatar
wildhog
Just had my whole top end replaced over the winter and did not touch the bottom end. Shop did do all the tests to make sure engine was good enough for a full build. If I had to do it over again, I would have spent the extra 8-10k for a 416 short block or a complete LT4 factory engine. I've got all the top of the line parts head, cam, headers, and all the extras and sitting at 740WHP but there is more on the table but the bottom end is the weak link. Next will be a 416 short block and 1000 WHP. Really depends on your end goal hp, yes its a slippery slope and I'm down the rabbit hole and having fun. As my tuner says it's Entertainment! Good Luck!
To opinions wanted
