I have a 2016 stingray with Michelin runflats. Last weekend was the first time ever I took it on the NYS Thruway for 50 mi each way. It started off a little jittery but as the wore on, I'm not sure if the car actually got more jumpy, or if the road was getting worse, or i was just noticing it more. At the end of the day I saw my pressures had uniformly risen from 34 to 39. I promised my wife I'd look into michelin non runflats, but most say no difference to smooth the ride. And no claim there's a pressure difference between the two tires. So probably not worth the $$$ to check it out....even for my wife!
The recommended tire pressure for all years/models of C7, is 30 psi cold in the morning- except for a short time when they increased the official pressure to 35 psi cold but changed nothing else. That was an evil trick to get another 1/100 (?) MPG on the fuel economy tests.
Later, GM people admitted that 35 psi cold gave a harsher ride, poorer handling, and more tire wear. All bad and no good, unless you were GM trying to impress the Feds.
Our Owner Manual does recommend higher pressures for sustained high speed driving, we should be so lucky as to have that problem.
Good history to know--I had no idea. I'll try that when I go down to the Finger Lakes tomorrow.
Much thanks my friend!
There is an error in my previous post- I'm told the cars that got the 35psi door sticker also got the tire pressure warning recalibrated. Instead of the Low Pressure warning coming on at about 25 psi, it was set to come on at about 30 psi. So if your tires are set at 30, you may get the warning when you first start up on a cool morning.
The warning may or may not effect things like stability/traction control, etc. Those problems should disappear once the pressure gets above 30 as you drive.
And of course, other things can cause the issues mentioned in post #1.
Let us know what you learn!
I just came from a Discount Tire and utilized their free air check. The pressures on my '14 Stingray were all over the place: 27psi, 31psi, 32psi, 30psi and the tires were warm to hot!! I threw the tech $5 and asked him politely to set all 4 tires to 35psi while they are warmed up. I immediately felt the difference in terms of a harsher ride however I expect them to drop psi when they cool down. Will check them again when the weather cools down in the desert. We are still at 100 degrees during the day.
So I put my pressures down to 31 for my 2016 c7. To be honest, I couldn't say for sure 3-4 lbs made a difference. On a variety of country roads i did notice however that the chatter seemed to be much greater on those roads that tar had been used to fill cracks...so the tires seems to be slipping across the tar lines, or their contours. On roads without tar, it seemed less, and tolerable.
To come back to topic again, not worth trying a non run-flat to see if it'd make a difference, given the consensus that it probably would not.
