Track Rotors
Old Aug 17, 2025 | 02:42 PM
BME_DDS's Avatar
BME_DDS
5th Gear
Default Track Rotors
Any suggestions for replacement brake rotors that are good for track days? I burnt up the front rotors after 2 track days at Road America - developed heat spots. I didn't think I was riding on the brakes too much but it's possible. I was using Carbotech XP10 front pads and XP8 rear pads
Old Aug 17, 2025 | 04:34 PM
BrunoTheMellow's Avatar
BrunoTheMellow
Girodisc or cheaper alternative DBAs. Buy at kns brakes
Old Aug 17, 2025 | 04:52 PM
96GS#007's Avatar
96GS#007
You probably melted the pads and you're seeing the deposits from them on the rotors.
Regardless.....I use Girodisc rings with the factory hats in the front and Girodisc rears. I buy via KNS Brakes.
To keep the heat transfer down, I have titanium shims between the calipers and pads. The shims are also from Girodisc and they drop right in.
Old Aug 17, 2025 | 09:09 PM
BME_DDS's Avatar
BME_DDS
5th Gear
Thank you!
I’ll follow up with them to order some new rotors.
Would you recommend upgrading the pads as well if those overheated?
Old Aug 18, 2025 | 01:12 AM
96GS#007's Avatar
96GS#007
Originally Posted by BME_DDS
Thank you!
For that track and the weight of the car I’d go at a minimum XP12 F / XP10 rear. If you’re on Sport Cups or Supercar 3Rs or other 100TW tire I’d go XP20 / XP12.
Old Aug 20, 2025 | 06:41 AM
RdRaceZ07's Avatar
RdRaceZ07
5th Gear
Another vote for girodisk rotors here as well with Hawk 70/60 pads.
To Track Rotors
