C7 2014
Old Sep 9, 2025 | 06:29 PM
brothertown#3's Avatar
brothertown#3
1st Gear
Default C7 2014
My key fob isn't working, put new battery in. Still won't open doors to the car. Then if I used the trunk key I could open the door release in trunk, go in and start motor and as long as I sat in car I can turn motor on and off. Once I leave the door locks and will not open unless I go thru the trunk routine but now it won't start at all.. I have power to the radio, the dash will come up but engine won't start even if I put FOB in the steering column and eventually the dash screen shuts off.. what are my options before I have to tow in to a shop?
Old Sep 9, 2025 | 06:33 PM
Trebor's Avatar
Trebor
Do you have a second key fob that you could try?
Old Sep 9, 2025 | 09:36 PM
RonC7's Avatar
RonC7
How old is the car battery? Get it tested? Charge it? A battery over 3 - 4 years old is suspect.
Are you putting the fob in the steering column slot in the correct orientation?
New fob batteries may have been on the shelf for a while. A fresh battery will read 3.25 volts or above.
See this thread about adding another fob:
https://www.corvetteforum.com/forums...te-c7-key.html
Ron
To C7 2014
