c7 corvette overheating
Old Sep 10, 2025 | 07:54 AM
Chrono_xcix's Avatar
Chrono_xcix
8th Gear
Default c7 corvette overheating
hello, I need someone to help on this problem am facing. so my car run normal when am driving someone that is long distance but driving back will experience my car blowing hot car and one time my temperature gauge was still reading 100. I went to the dealership for a check engine light and had an error code for PO700 and PO711 involving the transmission control system and trans fluid temepture sensor. would that be a the reason why my car is overheating the dealership told me that my thermostat is working fine. has anyone experience this problem also when I turn off my car the fan will still run for more than 10 minutes so I had to disconnect the battery so I wouldn't drain my battery. can the overheating be a battery wiring problem
Old Sep 10, 2025 | 07:56 AM
Chrono_xcix
8th Gear
Old Sep 10, 2025 | 08:21 AM
Tinkertech's Avatar
Tinkertech
Thermostat is bad.
Old Sep 10, 2025 | 11:44 AM
Laguna Blu's Avatar
Laguna Blu
Fill out your profile, please.
Old Sep 14, 2025 | 07:19 AM
Tinkertech's Avatar
Tinkertech
If this is a 14-year model it could also have a bad radiator fan controller, you would need to replace the complete assembly, fan + controller sold as one assembly.
To c7 corvette overheating
