What’s up? I have a manual transmission c7. Before I got it serviced it was vibrating by the clutch shifter. I had to replace the clutch and I got the flywheel resurfaced but now I still have the same vibration.
1) No idea what a clutch shifter is
2) The flywheel is a dual mass flywheel and it's not designed to be resurfaced.
3) The flywheel is balanced with the crank/rods/pistons. Resurfacing and/or random installation can cause engine damage
3) "replacing the clutch" is a broad description. Pressure plate? Clutch disc? Clutch Release Cylinder? All of the components?
4) There is no physical connection between the clutch assembly and the shifter. It bolts to the torque tube and the linkage goes aft....to the transmission.
If you took it somewhere, I'd say you got screwed. If you did it yourself, this is why there are factory service docs.
My ignorance and serious question, how would you go about changing out a flywheel in these if they need to be balanced to the crank/rods/pistons? I've never heard of this
Find a shop that can do NVH (Noise, Vibration, Harshness) testing....other than that you will only be guessing...now dealerships should have a Picoscope and the accelerometers to do this testing...maybe !!....other shops that use this advanced testing equipment can pinpoint it for you....vibrations can be difficult to diagnose without this advanced testing equipment.
Before you remove the old flywheel, you pick reference points on the old flywheel (like one of the balancing pins and one of the crank bolts) and mark them.
The actual flywheel itself is neutral balanced. The factory adds balancing "pins" as needed when the assembly is balanced. When you install the new flywheel, you install balancing pins in the same location as they were installed on the old flywheel. You then use your reference marks to install it in the same position on the crank as the old flywheel.
GM used to do this in reverse on the later C4s. The crankshaft balancer would have pins in it and if you replaced the balancer you had to install pins in the same place. I have a bag of the pins laying around somewhere. Back in the day GM had a specific part number for the Gen 2 LT4.
