Coolant smell
Old Oct 14, 2025 | 02:32 PM
mhcampbell60's Avatar
mhcampbell60
2nd Gear
Default Coolant smell
I have a 2017 stingray. After driving moderately I have noticed a coolant smell. After noticing I drove a second time and watched the coolant guage and it did not get excessively high. Is this normal or something to get service for.
Old Oct 14, 2025 | 03:09 PM
GOLD72's Avatar
GOLD72
If you can smell it, it might be a leak but not enough level lost to cause a temperature issue yet. If a leak, most likely at a hose or at the water pump. Water pump seals can leak initially so slow it might be a long time before you can see a liquid puddle on the floor. If no sight of a liquid leak, check the expansion tank level every few hundred miles for any loss of level there.
Old Oct 14, 2025 | 04:10 PM
Macleod52's Avatar
Macleod52
Did you recently have the coolant flushed?
Old Oct 17, 2025 | 12:42 AM
bearone2's Avatar
bearone2
coolant level correct??
Old Oct 17, 2025 | 09:54 AM
mhcampbell60
2nd Gear
Default Coolant
Yes checked level and good there. I have service appointment Monday and most likely will do flush and have all hoses checked. Based on Carfax it does not appear system has been flushed. Miles are low 27k but car is 10 years old.
Old Oct 17, 2025 | 12:50 PM
Macleod52's Avatar
Macleod52
Coolant flush should have been done 5 years ago. Hopefully the smell is nothing major.
Old Oct 17, 2025 | 11:13 PM
aklim's Avatar
aklim
Maybe delay the appointment and dye the coolant and pressure test it?
Old Oct 19, 2025 | 11:43 AM
user051728's Avatar
user051728
How bad is the smell? Like a faint whiff? Or a stench? I've noticed on some really hot days I occasionally would get a faint whiff of coolant smell. It seems to have gone away when I replaced my thermostat. Perhaps its a sign of a thermostat going? If it's particularly strong I'd be looking for a leak though.
Old Oct 19, 2025 | 11:53 AM
GOLD72's Avatar
GOLD72
Let us know what the dealer finds if a leak.
To Coolant smell
