C7 z06 start up
Old Oct 28, 2025 | 08:17 PM
arabz06's Avatar
arabz06
1st Gear
Default C7 z06 start up
Trying to figure out what this sound is
Factory starter went out on . So I replaced it with a reman and that didn’t work so I got a acdelo and another factory starter both brand new and they both make this sound .
any ideas what it is ?
I attached a video \/ below
File Type: mov
Old Oct 29, 2025 | 10:34 AM
kodpkd's Avatar
kodpkd
Can you look inside at the main engine flex plate teeth. Turn the engine over and see if it meshes then.
Let us help you. Some times your profile info will help.
Old Oct 29, 2025 | 02:08 PM
9sec's Avatar
9sec
right off the bat it sounds like the starter teeth are hitting the flywheel not meshing. need to pull the starter and look at the teeth on both the starter and flywheel
To C7 z06 start up
