Engine Chatter......
Old Nov 9, 2025 | 09:05 AM
Laguna Blu's Avatar
Laguna Blu
Default Engine Chatter......
I've noticed that my engine is quite chatty recently as the weather in AZ has become more reasonable in the recent weeks. I have started driving with the windows open and the occasional top off and it has become apparent that my LT-1 is very chatty and I'm wondering if it's normal or if it's the culmination of 70K miles of cylinder deactivation/oil starvation on four cylinders that has been taking its toll and that the engine is, in essence, designed to fail as so many other GM and Mopar V8's have already done due to to this crazy method designed to meet EPA mandates.....
Old Nov 9, 2025 | 09:54 AM
96GS#007's Avatar
96GS#007
You have to have a "before and after" comparison to know if anything is wrong via the almighty internet. The Gen Vs are noisy in general. The HPFP makes quite the racket. Just going from hot air to cool air can make it sound different due to the air density changing.
If you're really worried about it...
- Pull the valve covers off and check the valve springs to make sure one of those didn't break
- Drain the oil and send it to Blackstone or lab of your choice. If something is failing, you'll likely see some high metal content in the oil even if it looks fine when you drain it.
- Use a mechanics stethoscope and listen around the engine for an area that seems excessively loud vs other areas...ie an indication a lifter is going.
- Take it to a shop for a more in-depth diagnostic and peace of mind
Old Nov 9, 2025 | 03:02 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
We've now had four modern Corvettes for over 250k miles total, every one of them sounds like a big rig truck at idle and not much better in cruise.
Current C7 A8 has 65k including a fair amount of autocross and track time plus road trips in V4 mode, sounds just as noisy today as when it was new.
When you fly a single engine airplane over bad terrain, the engine seems to go into "automatic rough". Something similar happens when we worry about our car engine.
Here's hoping yours is ok...
Old Nov 10, 2025 | 08:54 AM
Tinkertech's Avatar
Tinkertech
Just to be clear.
Are we talking about real valve springs or the infamous AFM lifter springs or also known as plunger springs according to Chip?????
Old Nov 10, 2025 | 11:37 AM
Laguna Blu's Avatar
Laguna Blu
I decided that caution is my friend, the first mod will be swapping the yellow springs out for the blue springs, new plugs and wires.......
Old Nov 10, 2025 | 05:55 PM
chris1911's Avatar
chris1911
My clicking gets pretty loud between 1500 and 2000 RPM. It sounds like the high pressure fuel pump chatter, but louder. I seem to hear it more with the windows up, than down. I also don't hear it at idle in park or neutral in the garage. Drives me nuts. I have had the valve covers off, and all the springs look good and it sounds fine to me. I will be taking it in to get it looked at.
Old Nov 11, 2025 | 07:32 AM
Tinkertech's Avatar
Tinkertech
Check for fuel line hitting the firewall.
Some fuel lines had / developed chatter due to a bad inline check valve.
Old Nov 11, 2025 | 10:26 AM
chris1911's Avatar
chris1911
Yes, there is a service bulletin for that i would like to have looked at.
To Engine Chatter......
