Another ECU lost communication thread
Symptoms: can't write new tune to ECU
The car sat with battery unplugged for a few months. Could the ECU lose its programming?
What is plugged:
- alt
- 2 ground plugs behind heads
- 2 hot wire to the engine fuse box
- 5 blocks under the engine fuse box. I checked that all pins are straight
- starter (1 big wire + plug)
I have +12V coming to those ECU fuses:
- fuse 4
- fuse 8 ("LOGISTICS 30A") is not present but I have pins coming to it, not sure if prev owner messed with that
- relay 61 tested: OK
What's not plugged:
- plugs
- many things from front engine
- anything above HPFP/valley
- suspensions
- maybe I forgot a ground or hot wire somewhere?
Yet, with fuse box connected I should be able to talk to ECU with my scanners right?
But I can't, either with GDS2 or HPTuners
Ignition is ON, dashboard is ON, all interior lights working, windows etc
Battery a bit low at 12.03V
Charged a few hours to 12.90V, same issue
0x541: B1395 - Control Module Voltage Reference Output 1 Circuit (Pending, Current, Old, History)
0x541: B3205 - Driver Window Motor (Pending, Current, Old)
0x541: B3210 - Passenger Window Motor (Pending, Current, Old)
0x541: B3600 - Passenger Compartment Dimming Request Signal Circuit (Pending, Current, Old, History)
0x541: U0100 - Lost Communication With ECM/PCM A (Pending, Current, Old, History)
0x541: U0131 - Lost Communication With Power Steering Control Module (Pending, Current, Old, History)
0x543: U0422 - Invalid Data Received From Body Control Module (SES, Pending, Current, Old, History)
0x54E: C0575 (Pending, Current, History)
0x54E: C0580 (Pending, Current, History)
0x54E: C0615 - Left Front Position Sensor Malfunction (Pending, Current, History)
0x54E: C0620 - Right Front Position Sensor Malfunction (Pending, Current, History)
0x54E: U0100 - Lost Communication With ECM/PCM A (Pending, Current, History)
0x54E: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module (Pending, Current, History)
0x552: B1277 - Microphone 1 Input Signal Circuit (Current, History)
0x552: U0100 - Lost Communication With ECM/PCM A (Current, History)
0x554: U0100 - Lost Communication With ECM/PCM A (SES, Current, Old, History)
0x7EA: U0100 - Lost Communication With ECM/PCM A (Permanent)
Grounds I tested and OK:
- driver head
- pass head
- driver engine bay (2)
- passenger engine bay (1)
- the small black wire at the battery negative
Is there other power source going to the ECM apart from the ones I listed?
Current flows on the ground side which goes back to the battery…many shade tree mechanics don’t know what the ground does…if a module draws 5 amps that 5 amps must return to the battery via the ground wire…a ground isn’t a static thing…if all 5 amps gets back to battery negative you will have ZERO voltage drop…that is what you want !!…most voltage drop issues I see are on the ground side…that’s why 99% of mechanics can’t diagnose a simple light bulb circuit.
You mentionned power steering module so I double checked it and one of the 3 connectors on it wasn't plugged correctly!!
Now I have ECU communication again
New tune is being written to the ECU atm
If module isn’t plugged in you won’t have communication downstream to the ECM !!
