In April or May I will be picking up my new, to me, 2017 GS M7 in NC and driving it 850+ miles home. The car has 17.5K miles on it and from what I gather, other than engine oil changes, all other fluids are original. I am speaking with a local performance shop about doing, the trans, differential and clutch fluids and they recommend Amsoil products. I would appreciate insights on this manufacturer vs using GM products.
If the car has had the oil changed and is at 17.5K miles, the only fluids needing change are the coolant and clutch fluid. The OM recommends changing the coolant every 5 years/150K miles and changing the clutch fluid every three years. If the coolant is the original coolant, it is long overdue for change (it should be coming up on its second change instead of its first change). The 5 year change interval works well and I have used it on all of my GM vehicles since I purchased my C5 in 1997. When changing the coolant, ensure you use the correct coolant mixture as the C7 uses a mixture of 40% DexCool/60% clear drinkable water. Purchasing a premix of 50/50 coolant will not work.
The transmission and differential fluids are not due for changing until the car hits 45K miles. I track my car and changed the transmission and diff fluids at much fewer miles, but the OM recommendation is fine for street-driven cars.
I used the GM fluids and they have worked well. I have never used AMSOIL fluids as I see no advantage. They might be better, but that doesn't mean they will actually lubricate the engine any better than the GM fluids will.
When I purchased my 2014 I changed all of the fluids. There can be issues with a number of fluids not being correct, full, or done correctly. You never know what kind of monkey juice was put into your car. I would recommended the GM, ACDelco fluids. These aftermarket companies love to come up with there own version of correct fluids, even when they don't really meet OEM specs.
Reason I am asking is that I don't know the shop and only going by on-line recommendations and reviews. They are a chevy performance shop that really doesn't do routine maintenance but are willing under my circumstances.
As I have (2) C7's, one with 72K miles and (1) with 29K miles, I have always used the GM fluids with no issues. The clutch fluid will be DOT 4 fluid, and can be most any brand as it is a brake fluid. As other ops's have stated, the (2) main fluids Coolant & clutch need to be changed, but for my two cents worth, if I was making the drive you are planning, I would change all fluids, especially the M7 transmission, at it tends to be a bit nothy in the 1 to 2 shift & and fluid change has helped that issue some especially when the trans is cold.
Is this local performance shop local to you or to where the car is located? I have never had any service done at a performance shop. I have done my own or let the dealership handle it. When the car was under warranty, I had the dealership change the oil once per year. After the 5-year powertrain warranty expired, I changed the oil and coolant myself. I changed the trans and diff fluid as well. My clutch master cylinder had to be replaced just before the 3-year B2B warranty expired, so I didn't bother changing the clutch fluid at three years.
I have always used AMSOIL Signature Series engine oils in all of my past and current C6 and C7 vettes and a past Caddie CTS 3.6L sport wagon for accumulative total of several hundreds of thousands of miles. Also AMSOIL and Redline DEXRON III ATF products in all of my C5 thru C7 manual vettes. I have used AMSOIL Severe Gear differential gear oils in 2006 thru 2008 C6 vettes with excellent results in stopping slow speed turning clutch pack chatter. However, DEXRON LS was introduced for factory fill of differentials for 2009 and it has been excellent in preventing slow speed turning clutch chatter. That is what I have used for my 2011 and 2019 Z’s. AMSOIL products are very good and you will not go wrong with them. JMHO
Used Mobil1 0W-40 during the warranty period. Switched to Amsoil Signature 0W-40 and noticed engine was a tad quieter, but it comes out cleaner than the Mobil1 when I change it. I see many HP Corvette shops now use Amsoil such as Lingenfelter.
Congrats on your new purchase! Pictures...I have a buddy that swears by Amsoil, I always use exactly what's recommended by the owner's manual even if I have to provide it to the shop. Never heard a bad thing about Amsoil.
FYI....
If you change your coolant and are mixing it yourself (not using premixed), make sure you use DISTILLED water !! Do NOT use tap water which contains minerals that may be deposited throughout your cooling system.
Also, you can't go wrong with Amsoil premium products.... I replaced the trans fluid on my Vette ('08 C6M) with Amsoil Signature series ATF and the trans shifts smoother.
AMSOIL was the first to produce an API certified fully synthetic motor lube oil for gasoline engines in 1972. I am pretty sure they know what they are doing in Superior, Wisconsin after 50+ years.
FYI....
Good point!! I use distilled water in my mix as my subdivision supply is well water with high mineral content.
FYI..……
Another point for DIY’ers - Do not make the mistake in using an DEXRON 6 compliant ATF for a TREMEC M6 or M7 manual gear boxes!! It is too thin and was introduced as a more fuel efficient fluid for A4, A6 and A8 autos. The M6 and M7 manuals must use an ATF equivalent to the older (and now superseded) DEXRON 3 fluid. Examples of DEXRON 3 fluids are AMSOIL ATF, AMSOIL TorqueDrive, Redline D4, etc, all of which I have used in my Z vette M6 and M7 trannies.
FYI....
Typically, DISTILLED water is NOT recommended for use in automotive cooling systems. Distilled water is "ionically hungry" and will strip electrons from the metals in your cooling system as it attempts to rebalance itself. Softened or filtered water is fine.
I encourage you to look it up yourself.
The "destilled" water you can by in a shop is perfect for your cooling system. It is what I used in all my vehicles for the last 40 years. There is also destilled water that undergoes multiple destilling processes and is very pure. That might be a problem, but you can't buy it in a shop anyway and it is much too expensive.
I also did not use distilled water, I used normal bottled drinking water.
I understand the confusion. Every place I look, it says to use distilled water.
But this is what the 2014 and 2019 C7 manual says:
From the manual>
"40/60 coolant/water mixture of clean, drinkable water and use only DEX-COOL® Coolant".
I think the reason is because the distilled water boils at a lower temperature.
The most difficult part of changing the fluid, is to get the correct 40/60 mixture.
