C7 Shaking After Sitting
Old Mar 30, 2026 | 07:39 AM
Richard Le Page's Avatar
Richard Le Page
Default C7 Shaking After Sitting
Have a 2014 C7 Manual that I drove for the first time after winter to shake any cobwebs off and had a shake when accelerating. 53k miles. Put on about 4,000 a year.
This happens during any medium to hard acceleration at any speed. Turns on stabilitrak and rear axle service lights. Check engine light flashes as well. Oil change was last September. Axle/Trans fluid was about 12,000 miles ago.
Battery has always been on a tender so don't think its a battery issue. I've read from others it could be bad fuel from sitting, spark/injectors, etc. Just wanting to get the groups feedback.
UPDATES:
Codes are P0302 which is a cylinder 2 misfire. Going to replace the plugs and see how that works. Spark plug wires seem undamaged and fully seated on cylinder 2.
I did swap the coil driver from 2 to 4 and the issue did not move and is still on cylinder 2 so its at least not the coils.
Still going to get the plugs swapped (shopping prices right now because the dealer wants $704). I also don't want to drive it far on a misfire either.
Old Mar 30, 2026 | 08:06 AM
MissileDoc's Avatar
MissileDoc
The first thing I would check would be both ends of each spark plug wires to be sure they are connected to the coil and the spark plug.
Old Mar 30, 2026 | 08:11 AM
Zjoe6's Avatar
Zjoe6
Moderator
Agree, probably missing. I'd take it to a car parts store and read the codes.
Old Mar 30, 2026 | 04:22 PM
Richard Le Page
Old Mar 30, 2026 | 05:43 PM
cgladish's Avatar
cgladish
Long shot, but did you store it, parked on its tires? Possible flat spotting maybe?
Old Mar 30, 2026 | 06:46 PM
Richard Le Page
I did but it is throwing a P0302. I did put some updates in the original post.
Old Mar 30, 2026 | 07:16 PM
cgladish's Avatar
cgladish
Oops, sorry. I overlooked that point.
Old Mar 30, 2026 | 07:45 PM
Shane1974's Avatar
Shane1974
UPDATES:
Codes are P0302 which is a cylinder 2 misfire. Going to replace the plugs and see how that work, s. Spark plug wires seem undamaged and fully seated on cylinder 2.
When they sit for a while, they get injector issues. My bet is an injector needs replaced. Been there.
Old Mar 30, 2026 | 08:07 PM
fireicyhott's Avatar
fireicyhott
Default Same issue solved
Good evening Richard,
Your issue sounds exactly what I had a few weeks ago. My 2015 ZO6 I just finished an oil change on I took it up the road the next day and it was missing very badly throwing a P0304 code and the stabil track lights as well. I did a bunch of research on here and decided to pull the number four plug.
it looks pretty good so I decided just to change all six plugs while I was in there and the spark plug wires. I also bought a coil but I ended up not needing it. I actually found the spec on the spark plug wires and checked it with my own meter and all the wires actually measured more resistance than what the book calls for so that made me order the MSD super conductor 8.5 mm plug wires as they are very low resistance. I figured if I was going to change them I might as well upgrade
long story short changed all the plugs and the spark plug wires and the problem went away. So you may want to take your own meter and check your spark plug wires and at least change that also. Just my experience.
if you have any more questions shoot me a message
thanks Jeff
Old Mar 30, 2026 | 08:10 PM
Richard Le Page
thanks Jeff
Thanks for the detailed response. After more research it seems like 90% of the time that seems to be the issue/solution. Going to replace plugs/wires and hope that fixes it.
From sitting the winter I figured it might of fouled up the plugs or injector. Either way shouldn't be a 'horrible' fix.
Old Mar 30, 2026 | 08:35 PM
GreenVette9's Avatar
GreenVette9
If the misfire does not go away after you swap plugs, coil and wires, more than likely the injector is bad. Just replaced one on my c7 last week.
Before you spend the money on plugs and wires just swap the plug from another cylinder. If it is still there then swap a wire. If it's still misfiring then more than likely the injector.
Old Apr 1, 2026 | 07:52 AM
Tinkertech's Avatar
Tinkertech
Had just about the same issue on a 2006 GT Mustang 4.6L.
My scanner indicated a misfire on #2 cylinder.
Just replace 1 plug (#2 cylinder) and all was well.
My advice would be just change that one plug and go from there. It's cheap.
Old Apr 5, 2026 | 11:56 PM
Moving this over to C7 Tech for more discussion.
To C7 Shaking After Sitting
