Thermostat stuck open?
Old Apr 10, 2026 | 03:01 PM
IAIA's Avatar
IAIA
Default Thermostat stuck open?
My GS has been showing the "yellow" on the tach, for a while. Comes and goes. Even when fully warmed up and esp. on the highway (unless I'm revving high). The temp is usually ~170, even when the yellow disappears. I think it's supposed to be 180-220. So, seems the thermostat is stuck open. I've replaced them on other cars, but never on my Corvettes. Advice? Easily done? Thanks.
Old Apr 10, 2026 | 03:35 PM
kodpkd's Avatar
kodpkd
Easy Peasy. Just make sure you get the correct temp spec. What car do you have?
Old Apr 10, 2026 | 05:45 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Classic bad thermostat symptoms. Rock Auto sells the whole housing at a good price.
Old Apr 10, 2026 | 06:48 PM
IAIA's Avatar
IAIA
2017 C7 Grand Sport
Should I care whether it's GM OEM or aftermarket? (Motorad, Aisin, etc.) The price difference doesn't seem to be that significant.
Old Apr 10, 2026 | 08:59 PM
M61A1MECH's Avatar
M61A1MECH
Active Streak: 90 Days
When I replaced mine a few months ago I used went to Rockauto, they hade the best price, It is pretty simple, here is a link to the thread I started when I needed to replace mine, lots of good info and pictures.
https://www.corvetteforum.com/forums...s-done-it.html
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
2017 C7 Grand Sport
OEM is your best choice. Best place to buy, Rock Auto.
Old Apr 11, 2026 | 07:13 AM
Tinkertech's Avatar
Tinkertech
Always OEM!
Old Apr 22, 2026 | 04:26 PM
IAIA's Avatar
IAIA
Since the "other" thread of late that included R/R of the thermostat, I can say here that I just finished replacing mine. As mentioned, easy-peezy. This forum has always rocked with the helpful tips and information. Couldn't have done it without y'all. Thanks.
UPDATE: took it for a test drive and pushed it to see how the temp would adjust. No yellow on the tach after about 2 minutes, and rock solid 195 degrees.
To Thermostat stuck open?
