Stingray with 15 inch conversions.
Old Apr 26, 2026 | 03:03 PM
16callawayZ06's Avatar
16callawayZ06
Navigator
Default Stingray with 15 inch conversions.
Recently just purchased a c7 stingray with a Carlyle 15 inch conversion, obviously I know the setup is for straight line performance. But I spend most of my time on the mtn. If I switch tire setup how much corner performance am I losing with this setup? Is there anything I can do to be able to keep the 15inch setup and not lose much cornering ability? I’m sure I won’t be able to have my cake and eat it to I’ll have to pick
Old Apr 26, 2026 | 09:15 PM
PicaVette's Avatar
PicaVette
Some discussion:
https://www.performanceplustire.com/...g-Results-2025
Old Apr 26, 2026 | 10:21 PM
16callawayZ06
Navigator
Originally Posted by PicaVette
for some reason I can’t load that. I’m also meaning I’d change wheel and tire setup, but my question is with the other parts of the conversion how much cornering performance am I losing over stock?
Old Apr 28, 2026 | 08:03 AM
EVRGRN's Avatar
EVRGRN
You may get better responses if you specify wheel width and tire size front and rear.
Off hand, a 15" setup for the drag strip or even roll racing will have greatly reduced cornering capability.
Old May 3, 2026 | 11:52 PM
16callawayZ06
Navigator
no I understand my current tire setup would for sure hinder corner ability’s but I’m talking change wheels and tires, I’ve noticed no sway bar either, is that something I can add with 15 inch setup, along with changing wheels and tires and sway bar would cornering performance be close to stock?
Old May 4, 2026 | 08:38 AM
Lux's Avatar
Lux
Your only loss will be reduced braking if you go back to a standard wheel. The kit uses smaller rotors and calipers. The Knuckle and control arm won't really have any affect.
Old May 4, 2026 | 11:36 PM
16callawayZ06
Navigator
thanks! I knew I would with braking, but was really curious about the other parts. Going to look around and see if there is a sway bar that’ll fit the 15s so I don’t have to take that off every time, if I do oh well. Thanks again!
To Stingray with 15 inch conversions.
