Carbotech brake pads
#801
For normal driving, will these pads wear any different than the stock ones and could you also confirm that there is no low pad warning sensor on them either.
#802
Supporting Vendor
St. Jude Donor '11,'13
There is a wear tab on 1 pad. There is no different wear VS OE they will last longer than OE.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Stan0324 (04-01-2018)
#803
Supporting Vendor
Carbotech brake pads 100% made in the USA!
Use promo code z28 at check out and save $$ or call us direct at 216-780-8825 and save $$.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
F: ZO6/GS Iron rotor CT1405
R: ZO6/GS Iron rotor Ct1718
http://ampdautosport.com/brake-pads/corvette/
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#804
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#805
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#806
Supporting Vendor
Give me a call today..... 216-780-8825 best deals on Carbotech brakes or order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ promo code z28 @ check out.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#807
Supporting Vendor
Open Saturday for QUESTIONS and of course ORDERS... Give me a call at 216-780-8825. If you have no questions and know what you need, order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#808
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#809
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#810
Supporting Vendor
Designed by racers for racers, Carbotech brakes can be specified to meet the needs of your car and driving style. Just give us a call and we can recommend the compounds that will be perfect for your front and rear pads. If you know what you need you can order direct on line 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 @ check out for forum discount.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#811
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#812
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#813
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#814
Supporting Vendor
Brake Pads Street or Track Amp’D autosport has plenty of Carbotech compounds ready to go. Take 5% off your order when using promo code z28 at check out or call us direct at 216-780-8825 to order. Pre bed option is also now available for all Carbotech brake pads. Looking forward to hearing from you soon. Please call or email us with any questions.
Direct link: http://ampdautosport.com/
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#815
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#816
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#817
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#818
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#819
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#820
Supporting Vendor
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
