Borla Part # 11856 Atak C7 exhaust axle back Open Box special $1,400.00 @ RPI Designs
Platinum Supporting Vendor
We have an Open Box Special Borla Ataka c7 axle back system part # 11856, the mufflers have some scratches from improper return shipping back to us, there are no damage to the tips which would be the only visible part you would see once the system is installed. The First $1400.00 will gets this REALLY GREAT DEAL!!! Please call 1-888-257-8515 ext 2 Thanks, Don
C7 Corvette BORLA ATAK - The least most of the Borla Corvette Exhaust systems. If you're looking to increase the volume of your C7 Corvette Stingray exhaust, while also improving the exhaust tone and HP and Torque performance across the RPM range, than a Cat-Back exhaust is perfect for you, and there's no exhaust for your monster Chevrolet LS Small-Block V8 better than this new ATAK from Borla. Designed using Borla's Acoustically Tuned Applied Kinetic technology, this ATAK exhaust will provide your Corvette with a powerful and aggressive racing exhaust tone that will truly set it apart. This improved tone and increased volume doesn't come with any sort of compromise either--the ATAK will provide you class-leading performance gains, production quality, and minimal cabin drone! So, again, if you're looking to improve the over-all drivability and enjoyment of your Corvette C7, look no further than this incredible ATAK Exhaust from Borla!
Some C7 Corvette Borla systems use premium quality intregrated valves to ensure compatibility with multi-stage driving modes or fuel-saving cylinder deactivation systems. Borla uses patented computer-controlled technologies that allow them to adjust hundreds of variables, Borla sound engineers rely on over three decades of experience to refine the acoustical properties of each muffler, compensating for the varied exhaust flow caused by the valves. Once Borla is satisfied with the "Sound of Power" throughout all rpm ranges, the system is then put into production.
Attachment 47942818
Attachment 47942819
Attachment 47942818
Attachment 47942819
__________________
Attachment 47942818
Attachment 47942819
Attachment 47942818
Attachment 47942819
Was the exhaust ever installed in the vehicle? And are you sure that is 11856? I expected this http://www.borla.com/productImages/m...856_xlarge.jpg I am not seeing the NPP valves and the tips are mounted in the wrong orientation.
