What will be the "special surprise" on the new Z06?
#186
Maybe that's what the surprise is....they made attachment points for aftermarket roll cages with little to no modification.
#187
This is completely false. You really don't know what you're talking about. A convertible needs a rollbar to do HPDEs and to run down a drag strip, but a coupe with the targa pane in place doesn't.
#188
Here at Gateway if your running 11.50 or less you need a min of a roll bar regardless. (speaking of drag racing of course)
#189
True... I didn't elaborate. My point was that a targa doesn't have the more restrictive rules a vert is subject to. As you said, all cars have to have a rollbar at the drags once they get fast enough.
#193
I'd suggest the sales success of the 427 convertible in the last year of the c6 generation makes a convertible version of the LT4 in both manual and automatic versions a home run in the seventh generation.
#194
I am guessing it with be a lt1 with a little 1.9 supercharger from the ZL1. A 2.3 would have given it an easy 675hp.
I think the big surprise will be either an auto option or a convertible. Both would be insane
#195
What do you have in mind? It's an aluminum frame. I don't think "little to no modification" can be used in the same sentence when talking about a roll cage and aluminum frame. It's very expensive, because of the labor.
