Looks like the #'s are 620/650
kindly explain this DoctorV8,
regardless of what GM uses to get this weird *** power curve (assuming its even real for starters) I aknowledge the fact that its not a typical supercharged engine's graph unless they electronically restricted the power up top for some reason.
Consider this example, in which the torque number is greater than the horsepower number, but peak horsepower occurs higher than 5252rpm.
Torque RPM Horsepower
650 ... 3000 ... 371
650 ... 3500 ... 433
625 ... 4000 ... 476
600 ... 4500 ... 514
575 ... 5000 ... 547
540 ... 5500 ... 565
505 ... 6000 ... 577
465 ... 6500 ... 575
400 ... 7000 ... 533
It all has to do with the rates at which torque falls off, in the vicinity around 5252 rpm.
Correct, but as I stated before, the numbers are close for conservatively tuned stock motors like a typical Gen II-V small block. The "peak" hp is actually a plateau in your example, not just a single point. We are talking about subtle differences here.
You now have two graphs that prove you wrong and you don't want to admit that you were wrong? Trying to go around what you just said by saying but the numbers are "usually" close on stock tuned motors when the whole argument has nothing to do with those leaked numbers, everyone here are SIMPLY trying to prove to you that it IS possible mathematically.
Accept it and move on.
The HP peak "plateau" is still starting well after 5252 rpm. I guess to me, that engine's HP peak is not before 5252 as you were stating it has to be for an NA motor.
To quote a wise man from this forum whom I still have great respect for, have a day!
Throw a set of heads/cam in that car, redyno to see the tq curve shift to a higher RPM, and watch the HP climb. That's my point. Sorry to hijack the original thread.
using the very same 7th grade equation that you were questioning earlier? Or is there a different method you'd care to educate us on?
The Consigliere
Received 5,445 Likes
I wonder how the new mill's VVT impacts all this.
#33
#34
By the way I have the same Vettes as you, a Cyber Gray ZR1 and Red 90' ZR-1.
#36
1964 Corvette had four engines to choose from.
250HP/350 lb-ft
300HP/360 lb-ft
365HP/350 lb-ft
375HP/350 lb-ft
All four engines had the HP curve and the torque curve intersect at 5252 RPM.
250HP/350 lb-ft
300HP/360 lb-ft
365HP/350 lb-ft
375HP/350 lb-ft
#38
You do realize that HP is just a calculation based on RPM (and torque) and that torque is what is measured? Because of this the curves have to cross at 5252 rpm no mater what engine it is.
#39
As does every other Corvette engine. GM's internal policy to obey the laws of thermodynamics goes back to its inception.
#40
in the four examples I gave, each successive engine has the torque peaking at a higher RPM, thus while the peak torque does not increase(except for the 300 HP engine), the horsepower does.
