Sponsored by: GEM Motorsports
Cheap Wheels For The Track
Old 11-15-2014, 08:32 PM
Foxer55
Foxer55's Avatar
Default Cheap Wheels For The Track
I might be looking for a set of spare wheels for the track. I'm thinking once the Z07 gets here it would be possible to mount the Michelin Cup tires on a set of spare wheels for track only and just put Michelin SS on the OEM wheels for other use. I would be looking for a set of back wheels but I'm not paying any $500 a wheel for them. Who would make these wheels?
Of course, doing this would be a lot of work and money so I might just put some Michelin SS on the car and leave it at that.
Old 11-15-2014, 10:18 PM
Dr Chill
Dr Chill's Avatar
I wouldn't risk my life using a sub $500 wheel on the track with R compound tires in a car with the power, handling, and braking capabilities of this car.
Old 11-15-2014, 10:32 PM
OH THREE Z
OH THREE Z's Avatar
2018 C4 of Year Finalist
My plan is to give my OEM C6 Z06 wheels with Hoosiers already mounted on them a shot. My hope is that they clear my calipers and have a proper offset and of course look good. My car will be a non Z07 so your caliper clearance might be different than mine.
These wheels can be found for around 5-600 a set. Obviously your cups won't fit these though.
Old 11-16-2014, 01:57 AM
jamesw95
jamesw95's Avatar
Don't put cheap wheels on a high performance car for track use.
Old 11-16-2014, 02:51 AM
texasviany
texasviany's Avatar
What sizes are you running?
Old 11-16-2014, 04:17 AM
SBC_and_a_stick
SBC_and_a_stick's Avatar
Used c6 oem wheels for sure.
Old 11-16-2014, 09:07 AM
4GS7
4GS7's Avatar
Any wheel that fit a C6 ZR1 will fit a C7Z. Some of the test mules were running C6 Cup wheels.
I wouldn't go with C6Z fitment because I don't know how much bigger the base calipers are on the C7Z than the C6Z calipers. IIRC, the C6Z calipers were very flat and gave you a lot of spoke clearance.
Old 11-16-2014, 11:46 AM
thebishman
thebishman's Avatar
Agree with the above posters: I'd never place my life in the hands of cheap 'knock-off' type wheels on a race track, be it a road course or 1/4 mile. Spend the money and buy a set of OEM wheels that have been taken off someone's car, OR spend good money for high quality track only wheels.
Old 11-16-2014, 12:54 PM
mikefili
mikefili's Avatar
I too have my stock C6 Z wheels fit with Hoosiers and am hoping they will fit my C7 Z, it is not a zo7 car but stock C7 Z. I am sure the sensors will not work, would be great if I can use my almost new Hooisers though. Anyone know?
Old 11-16-2014, 03:20 PM
OH THREE Z
OH THREE Z's Avatar
285's & 325's
18 and 19 inch 10 spoke
Old 11-16-2014, 03:25 PM
mikefili
mikefili's Avatar
285's & 325's
I have stock C6 Z wheels
Old 11-16-2014, 03:43 PM
Cyclone09Z06
Support Corvetteforum!
Cyclone09Z06's Avatar
I have a set of F14 in 18x10 and 18x12 that I run my slicks on. I am being told that they would fit a C6 ZR1 so hoping they will fit my new C7 Z06 with the Z07 option
Old 11-16-2014, 03:56 PM
Leo the Lion
Leo the Lion's Avatar
Cruise-In II Veteran
I have a set of stock wheels off my c6 z06 that I will be putting in the for sale section when I return from vacation on the 22nd. Got to many sets of wheels and need to clean out the garage. I'll be glad to sell them for $400 and you pay shipping if they will fit your C7. PM me if your interested.
Bill
Old 11-16-2014, 05:13 PM
05dsom
05dsom's Avatar
I got a set of OEM speedline/GM cup wheels (black satin) from florida speed shop. They will fit over your CC brakes.
they are $1499, but may have a forum discount.
http://shop.floridaspeedshop.com/OEM...-20-156223.htm
https://www.corvetteforum.com/forums...-and-acc-.html
Old 11-17-2014, 11:26 PM
SBC_and_a_stick
Originally Posted by DOCZ- 1st Rate Corvette Parts & Acc.
Our OEM GM wheels are not cheap wheels however they are the lowest price you will find on new OEM GM cup wheels at $1499.00 per set plus shipping. We supply the majority of the other vendors and many Chevy dealers.. Once we establish the 2015 C7-Z06 shares the same offsets at 40/59MM, which are the same as the 2009-2013 ZR1, 2013 427 Vert, 2012-2013 Z06 with carbon package then they will be a great alternative wheel for the 2015+ Z06 customers. We also have the OEM GM Q8K machined face/grey anniversary cups for $1549.00 per set plus shipping. No core charges!!
Do you also carry the black version with red stripe?
Old 11-18-2014, 03:47 PM
4GS7
4GS7's Avatar
If they don't you can add the stripe yourself.
We've already seen those on C7Zs.
To Cheap Wheels For The Track
Old 11-18-2014, 05:03 PM
B Stead
B Stead's Avatar
There's not going to be very much tire selection in the 335/25-20 tire size. The Pilot Sport Cup 2 will probably only be offered as a run-flat tire in that size.
The next problem is that the 325/30-19 tire size has a fairly tall sidewall at 3.8". However, some tire availability is coming along:
RE-11 (new 200 treadwear compound)
Front, 275/30-19, calls for a 9.5" wide wheel
Front, 305/30-19, calls for an 11" wide wheel
Rear, 325/30-19, calls for an 11.5" wide wheel
Pilot Sport Cup 2
Front, 295/30-19, (not car specific and probably not a run-flat), calls for a 10.5" wide wheel
Rear, 325/30-19, (TR has both a Porsche-specific and a non-car-specific tire while the Michelin website only shows the Porsche-specific), calls for an 11.5" wide wheel
Also, r-comp tires will probably be easier to find in 18/19 or in 19/19. There is an R888 in 315/30-20 tire size.
Another note, Z06 front/rear wheel offsets are 40/59 while the base Corvette has front/rear wheel offsets of 56/79. Just use the correct wheel offset for the car and then use the wheel width that the tire calls for
Old 11-18-2014, 05:07 PM
SBC_and_a_stick
Thanks for the pics! I guess that is the best way to check ZR1 fitment on the C7 Z06.
I think adding -10mm of offset to all four corners will make the car look and handle much better without rubbing on the fenders.
I probably wouldn't add the stripe myself. Not sure it would survive the elements and would ruin the resale value.
Quick Reply: Cheap Wheels For The Track
