Conservative Z06 ECU Programming
hp/weight. It matters.
Now, if people want to address cooling fixes, that is another issue. That one has far more validity. Whoever thought that spinning a tiny blower up to 20,000 rpm, instead of using a larger blower spinning at only 15,000 rpm - to produce the same power, well.... not a good idea.
Personally, I will leave the car alone until the warranty is over , as I have done with my C6Z06 and CTS-V wagon. But if down the road I want more performance I can extract it. I feel it gives Manufacturers the ability to build cars we truly want, while staying within the guidelines and regulations we now live in. Give me the option to retain the warranty if I want. I'm not going street racing and don't really have time to go to a track, but to have a car that can carve canyons like nothing else is what I want.
Personally I am going to keep extending the warranty on my C6Z06 until I am sure there is a good fix to stop the motor from imploding itself.
My 01 Silverado is the only thing with ECU tuning, CAI and LT headers.
But then outside of the track crowd the car has more than enough power just as my lowly LS3.
Not a fan of cylinder deactivation neither.
Later, I took it back in 60F December. It went a best of 129 mph, and averaged 128 mph. That is the day I went 10.9 in it.
Even all-motor cars lose power due to high intake air temps and reduced timing.
That is why this story sucks. Every car does this.
I drove both the Z06 and ZR1 at Spring Mountain. At the end of a session in either car you could tell that both had fallen over a bit, and the LS9 was pushing 230+ water temps in Nevada desert hit. The LS7 was only breaking about 219 degrees, but straights that I was pulling 118-119 on at the beginning of the session were down to only 116 by the end of it.
You can't change the physics of how heat is going to slow things down, blown or unblown.
If you want to turn you're Z into a race car have it at, but GM is not going to underwrite your racing budget through their warranty.
They're trying to build a highly civilized amenity loaded sports car for the masses, and by the accounts of those who have them, that is exactly what they've done.
I think what we're seeing here by some are their unreasonable expectations crashing into reality. There's a reason why Viper struggles to sell a couple thousand cars a year (haven't Viper sales been in the hundreds for a few years now?). GM has decided they have no interest in that market.
So while most of us will be in love, some will be apoplectic and still others will troll them endlessly.
Someone help me understand what the EPA/emissions has to do with a 650hp car magically pulling timing and slowing down the 4th time it races someone? (at wot)
Blaming emissions seems like a crappy cop out here, it seems obvious they are trying to protect the engine due to the blower design and potential heat/cooling issues. Emissions shouldnt be a huge problem on a blown car to begin with and does the EPA even really give a damn or test WOT emissions?? Much less only on the 4th+ time it races someone or cares more and more about emissions as it turns more laps at a track? I'm just not sure what smog could have anything at all to do with this.
From what I'm gathering, it doesn't even seem like we are seeing any heat soak, but the computer pulling all sorts of timing etc before it even comes close to that point. If it is to that point or true heat soak, then that's a true engineering problem that never should have happened.
With the "we feel most owners will be happy with the level of performance..." comment...yes I think most people would be happy with 650hp Z06, but it seems like owners aren't getting what they paid for here. We'll see how this shakes out but if I paid 80k+ for a 650hp car with the heritage/assumption that has always been a road racing warrior and fast as hell at everything, and it's doing what it's doing....I'd be pretty upset.
I still hate the idea of a 3500lb FI Z06 but that's another issue and I sound like I'm trashing the car when I was stoked as hell for it
Correct me if I'm wrong in any the above but that's my thoughts..
This is one thing I like about my 2014 Z/28. The output never drops, the temps never trigger the ECU, and the car feels bulletproof when other cars are wilting around it. We'll see how this plays out, but I may end up sticking with my "slowpoke" Z28...
If you want to turn you're Z into a race car have it at, but GM is not going to underwrite your racing budget through they're warranty.
