Stone chips
A friend of mine used this when he brought home his Stingray and got it here without a chip or blemish.
It rolls on like paint, dries quickly with a clear but slightly matte finish, protects with a rubbery film, and can be easily removed when you are ready to show off your perfect paint.
A quart container will cover the front of a car about 5 times and costs only $39.99.
For more information, go to www.roadwarriorplus.com
You can view a quick video of the product here:
Here's a quick overview of how the product is applied, removed and protects.
Roadwrap has it's place. Many use blue painters tape but it is time consuming to put on, likes to lift at the ends, doesn't like water, ends up costing enough if you want to cover large areas, and is ugly except on a car that is painted painters tape blue.
Roadwrap will not win a beauty contest either, although, if you want to take your time you can cut and fit it reasonably well. I drove my Stingray home 150 miles on busy interstate and did not want one flaw in the paint before I would install Suntek paint protection. I was short on time and did the quick Saran Wrap style install.
In literally 15 minutes it was covered. I must confess my wonderful wife did help me. Lapping right over all joints and lights, only cutting around the drivers door, grill, and the wheel wells sped up the process. It did not reduce the lights in the dark. I also protected the rockers, front of the carbon fiber roof, and the mirrors. I did not care what it looked like. The goal was to get home before it snowed and to do it with out a rock chip. No ends or overlaps let loose except one end on a mirror that was not pressed down well. It even saw 90 mph for a brief stint. It did not reduce the headlights in the dark.
It is a very tough film, much tougher than the liquids and no waiting for it to dry or cure. The 100' x 18" roll will do close to 3 Stingrays with this much coverage for under $45 off Amazon. (Nov 2013) So for $15 it did what I wanted it to do cost effectively. I will use it for the Z.
and if you are looking for a great installer in south Florida?? these guys have done 1000s of cars. and use both types of film. http://www.autosupershield.com/ ask for Pepi or Wendy
I just had mine done, I would take a picture, but you can't see it at all, and the DSOM paint looks great. I also covered the side skirts and sills, because I know they are going to get scraped. JD
Tracwrap will not win a beauty contest either, although, if you want to take your time you can cut and fit it reasonably well. I drove my Stingray home 150 miles on busy interstate and did not want one flaw in the paint before I would install Suntek paint protection. I was short on time and did the quick Saran Wrap install.
* Wipe area (paint chip) with alcohol.
* Dab on some "factory" touch up paint.
(Make sure the dab of paint is higher than the surface)
* Let dry for a few days (3) or more than use a reusable 1500 stone made by Meguires (follow directions) to take the "lump" of touch up paint down to the original surface.
* Put the shine back with some rubbing/polishing compound, then switch over to a scratch remover to finish up with the final shine, then a coat or two with some cleaner wax like Mothers.
You will not see the repair, it will look completely untouched like factory again! As Indiana Jones would say: "Trust Me".
I will edit my post accordingly. Merry Christmas to all!
