Track alignment
Old Dec 31, 2014 | 10:42 AM
c7jim's Avatar
c7jim
Default Track alignment
Three questions
1.) How much negative camber is applied to suspension, front and rear, when set to track alignment?
2.) How difficult is it to set? Can I do it myself in my garage or does it need to go to an alignment show?
3.) Can you get away with track alignment on the street w/o excessive inner tire wear?
just seems like a lot of effort to change every time you want to go to the track. It would be nice if there were something like the caster camber plates I have have on my 2011 gt 500, which makes changing settings a snap.
Old Dec 31, 2014 | 11:29 AM
Bill Dearborn's Avatar
Bill Dearborn
I don't know how critical it is to the overall alignment but the C7 gas a rear caster setting which is measured by setting the angle of the knuckle by using a digital angle finder. That might be a little trickier to set up than what we normally do since it is probably difficult to attach the gauge to the knuckle or read it without removing the tire.
Bill
Old Dec 31, 2014 | 01:38 PM
johnglenntwo's Avatar
johnglenntwo
Default See the Manual!
Originally Posted by c7jim
Three questions
I have read they are recommending special settings in the rear.
To Track alignment
