Wind noise
Jan 11, 2015 | 11:41 PM
4th Gear
Wind noise
Has anyone noticed a wind noise in the rear, it sounds like wind being sucked in for the electronic differencial?
Jan 12, 2015 | 12:28 AM
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Tire noise perhaps? Big Michelins are noisy.
Jan 12, 2015 | 07:28 AM
4th Gear
No it is not coming from the tires, it is like rushing air!
Jan 12, 2015 | 07:36 AM
It is from the upper side vents behind the doors. They produce a good bit of noise
Jan 12, 2015 | 07:43 AM
4th Gear
That is where I think it is coming from as well!
Jan 12, 2015 | 08:47 AM
Mine is tire noise! It changes with every road surface. JD
Jan 12, 2015 | 08:59 AM
If its rushing air you are hearing, its one of a few things:
1. You are on the edge of the NPP flapper valves opening
2. The HVAC blower is running
3. Window/hatch not completely closed
#2 sounds incredibly like wind noise but it is simple to rule out. Just turn the climate control off.
Every time I think I have wind noise it is either #1, or #2.
Jan 12, 2015 | 09:08 AM
If you get the accessory mat for the back it drops the road noise level a bit (at least it did in the Stingray).
