Tpms
Old Jan 12, 2015 | 01:23 PM
Toilets's Avatar
Toilets
Default Tpms
Anyone making these yet? I need to get some extra ones for a different set of rims.
Old Jan 12, 2015 | 01:30 PM
Cyclone09Z06's Avatar
Cyclone09Z06
You can order from gmpartsdirect or local dealership you do not have to program car picks up automatically
Old Jan 12, 2015 | 01:35 PM
Toilets's Avatar
Toilets
It picks up automatically?? That is frigging awesome. Do you need to do anything so it can learn it or literally just start the car and go? Thank you
Old Jan 12, 2015 | 03:20 PM
HOUSEOFWHEELS's Avatar
HOUSEOFWHEELS
Supporting Vendor
St. Jude Donor '03 & '11
Default Gm TPS
In stock and on sale 140.00 set of four shipped
Bob
House of wheels
561-445-7606
Old Jan 12, 2015 | 03:51 PM
Cyclone09Z06
Yep just start the car and go, it is awesome.
Old Jan 12, 2015 | 04:15 PM
dar02081961's Avatar
dar02081961
Actually this is only partially true. If its like in the past and I think it is, unless they have different part numbers for each wheel position, which I doubt.
You will have to use one of several methods to "program the car" to tell the car which sensor signal corresponds to which wheel position.
If you swap out 1 sensor the new position would be assumed so no issue.
Old Jan 12, 2015 | 06:41 PM
TEXHAWK0's Avatar
TEXHAWK0
The automatic learn sensors are not 100% fool proof. Sometimes it takes several hundred miles for them to learn new positions.
You can manually put the car in learn mode by
Turning the car on...
Setting the DIC to the tire pressure screen...
Then press SEL until the horn beeps and the screen shows learn mode.
At this point you can use a hand held trigger tool to reset all the sensors, or just drive the car while still in learn mode and they should reset within about 10 minutes.
https://www.corvetteforum.com/forums...ere-s-how.html
To Tpms
