PDR disk missing
Old Jan 18, 2015 | 10:41 AM
2vetteEd's Avatar
2vetteEd
Default PDR disk missing
I toke delivery of my new Z06/Z07 last Tuesday, and today I decided to check out the PDR.
Pushed the PDR button on the home screen, and got a message back....No disk installed! I opened the glove box and sure enough no PDR disk. No PDR disk anywhere on board.
No where in the manual does it mention that the disk comes with the car. Correct? I tried two disks from different camera's, but they wouldn't fit.
Anyone know exactly what type I need to make this critter work?
Old Jan 18, 2015 | 10:45 AM
rwillitt's Avatar
rwillitt
Yeah, it doesn't come with the card. SDIO card, class 10, has to be formatted FAT32 so 32GB card unless you use a 3rd party utility to format a larger one.
Old Jan 18, 2015 | 10:46 AM
JackTripper's Avatar
JackTripper
Turn 12!
They do not come with the car. Just buy one, format it to Fat32 and install it in the slot in the glovebox.
Old Jan 18, 2015 | 11:43 AM
pmzangag's Avatar
pmzangag
I bought this one. Works fine. As stated above, if you get larger than 32gb then you must reformat for fat32.
Amazon.com: PNY Elite Performance 32GB High Speed SDHC Class 10 UHS-1 Up to 90MB/sec Flash Card - P-SDH32U1H-GE: Computers & Accessories Amazon.com: PNY Elite Performance 32GB High Speed SDHC Class 10 UHS-1 Up to 90MB/sec Flash Card - P-SDH32U1H-GE: Computers & Accessories
Old Jan 18, 2015 | 12:23 PM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Don't forget to download the Cosworth toolbox.
Old Jan 18, 2015 | 12:35 PM
RandomTask's Avatar
RandomTask
I bought this:
Amazon Amazon
Formatted to exFAT32 with this:
http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
Works great! 6k+ minutes of recording time.
Old Jan 18, 2015 | 03:25 PM
harley2's Avatar
harley2
I have this card coming! Do i have to do anything to it or jus insert?
Old Jan 19, 2015 | 04:33 AM
2vetteEd's Avatar
2vetteEd
Thanks for the link. I have an Amazon account, so I just purchased this one.
Old Jan 19, 2015 | 08:59 AM
bluedevil 1's Avatar
bluedevil 1
Indeed, the car does not come with a SD card. That is unless you take delivery at the museum. At the museum, they are kind enough to supply you with a 8GB card. I just purchased a 256GB card and reformatted it to FAT32. The PDR now says that I have over 100 hours of recording time. (that should last for a couple of days)
Old Jan 19, 2015 | 10:25 AM
pmzangag's Avatar
pmzangag
Just insert it
Old Jan 19, 2015 | 12:31 PM
b4i4getit's Avatar
b4i4getit
You would think that at the cost of this car GM could find a way to include an SD card already installed and ready to go.
Old Jan 20, 2015 | 03:59 AM
2vetteEd's Avatar
2vetteEd
You got that right!
Old Jan 20, 2015 | 01:52 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
How many hours of recording time will I get with the 32gig card?
Old Jan 20, 2015 | 02:44 PM
z51vett's Avatar
z51vett
I bought from Best Buy a SanDisk #10 32GB Ultra Plus SDHC UHS-1 card speed up to 40 MB/s 266x around 20 something dollars. I've tested in both valet and regular road use works great.
z51vett
Doug
Old Jan 21, 2015 | 11:39 AM
dar02081961's Avatar
dar02081961
Quote from one of several sources from Cosworth.
"Recording time depends on the capacity of the memory card (not included), but an 8 GB card can record approximately 200 minutes, while a 32 GB card stores up to about 800 minutes – more than 13 hours of driving time."
http://www.chevrolet.com/corvette-st...-recorder.html
Old Jan 21, 2015 | 01:01 PM
george vee's Avatar
george vee
Thank You
Old Jan 21, 2015 | 01:11 PM
pmzangag's Avatar
pmzangag
IIRR when I installed the disc, it indicated that I had somewhere around 390 min of recording capacity.
To PDR disk missing
Old Jun 25, 2017 | 03:54 PM
Sam Mackay's Avatar
Sam Mackay
5th Gear
Thanks. I returned the 80 GB and purchased a 32gb. PDR is working fine. Again thank you.
Old Jun 25, 2017 | 07:34 PM
WilliamCall's Avatar
WilliamCall
Originally Posted by 2vetteEd
You got that right!
Also, due to the file size limitations of FAT32, the actual recording time of a single file is about 99 minutes. So, if you are thinking of taking a cross country trip and recording the whole event, the PDR will stop recording after 99 minutes.
Old Jun 26, 2017 | 06:37 AM
Sam Mackay's Avatar
Sam Mackay
5th Gear
Thanks to all of the replies to my question.�� My PDR is up and running perfectly with a 32gb SD Card.
