Im curious is the rear wing possible to remove without damage?
I like the look of the of the brake light small wing,like on the normal c7.
I do not own yet,i will probably wait it out until the
rush goes away.
And then grab one at a nice discount.
rush goes away.
Is the rear spoiler dealer-installed as part of the prep?
Are there factory pre-drilled holes in the body for mounting the rear spoiler?
All three levels of aero effects use the same basic spoiler, which is mounted at the factory. The size of the panels and end plates bolted and taped to it vary.
