What is the difference between "Teen Mode" and "Valet Mode" in the PDR? Also, does the recording start as soon as you start the mode or only when car is running? I would want the recording to start only when the car is running, then stop when car is stopped. Is that possible?
I am planning to drop it off at the dealer to have some work done that will take 2-3 days. If it runs continuously, then a service person could abuse the car one evening and then the next day, while still in the shop, the abuse would be overwritten.
No such thing as Teen Mode on the Stingray, not sure about the Z06.
The Valet Mode will only record when the car is on (even if the engine is off). If you get a big SD card, it should record a few days with no problems.
