Track alignment for DD?
Old Feb 5, 2015 | 10:42 PM
krisa9977's Avatar
krisa9977
Originally Posted by Cyclone09Z06
Lawdog why did they grind the cam bolt? I just move washers. I set up for -2.5 camber front (2-washers) and -1.5 rear(1-washer). Each washer equals .5 so I can set at home for street -1.5 front and -1.0 rear by just moving washers. than all I do is set toe.
It is a good idea to grind bolts and keep washers if you can get more negative camber. This way you can have wider track and don't need spacers
Old Feb 5, 2015 | 10:46 PM
Flyboy22's Avatar
Flyboy22
I saw that also, from the factory with toe out in the rear! wtf
Out of curiosity, what will this do to daily driving? Tendency to oversteer / drift?
I'm definitely a novice to the handling effects of changing the alignment.
Old Feb 5, 2015 | 10:56 PM
Cyclone09Z06's Avatar
Cyclone09Z06
This makes good sense. I had always just moved washers so I was curious.
Old Feb 5, 2015 | 11:04 PM
Cyclone09Z06
My understanding is with toe in in the rear the car turns in better and you can apply power earlier. I was told to run 1/8 toe in in the rear on my 09Z06 so I always have. I have never run toe out. On my C7Z the owners manual says to run basically zero toe in the rear, I didn't listen and set up for 1/16 toe in.
Old Feb 6, 2015 | 10:34 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Maybe I'm missing it, but what did they set the rear caster to and how did they set it? The C7's adjustment is different than a C6 and the rear caster has to be set using a digital angle meter. I've already seen a couple cars from the factory with incorrect rear caster settings. Supposedly it is very important to verify the rear caster stays at 0.0 after making the camber and toe adjustments.
Old Feb 6, 2015 | 11:30 AM
One Curve at a time's Avatar
One Curve at a time
Originally Posted by lawdogg149 View Post
I have left mine on the track alignment. Cost me $175 to get it aligned thanks to them having to reprogram the steering system. Yea you will love how much better it handles with the track alignment. I haven't seen any more wear on the tires I am watching them closely
This is great info!
OP I run my track settings on the street and have been for years, it will wear the inside a bit. I usually heat cycle out my tires before wearing out my tires so I don't worry too much about it.
To all this so true... Thx
Old Feb 7, 2015 | 09:24 AM
stevebz06's Avatar
stevebz06
Originally Posted by thebishman
If you aren't having any noticeable increase in tyre wear running the track alignment 100% of the time, I'll leave mine in that alignment all the time also.
Lastly, I'm wondering if the M7 car that Randy Probst drove in the recent MT GT-R Nismo versus Z06 article didn't have a bad alignment since he stated that the car felt unbalanced. That has been the only time I can remember a review saying the car wasn't really 'easy' to drive fast on a road course.
Bish
My thoughts, exactly. My first Vette was nearly undriveable as delivered and still was after I took it back to the dealer. It took a trip to a shop that specialized in high performance cars before I had a car that could be driven confidently.
I was hoping that after all these years that they would be paying more attention to these things, but I guess not. Everybody seems to be fixated on power issues, but I bet the Willow Springs lap disappointment came from a bad alignment.
