A8 hold extended.
Old Feb 6, 2015 | 11:23 AM
dcher's Avatar
dcher
Default A8 hold extended.
According to Mike Furman, as of this morning, the A8 hold has been extended until late next week.
I certainly hope GM gets it right. They certainly will have had the opportunity with the extended hold they have placed on these cars. Is it a GGT issue or QC issue? Who knows?
Old Feb 6, 2015 | 11:26 AM
BOBSZ06's Avatar
BOBSZ06
There are plenty of A8 Stingrays in use.
There were many A8 Z06 on the line being built prior to the retail cars.
I have said and continue to believe this is a GGT issue.
But if it is not...then what is the problem with the A8/Z06?
As far as a normal QC hold...hardly.
http://www.stingrayforums.com/forum/...tml#post126544
Old Feb 6, 2015 | 11:30 AM
dcher's Avatar
dcher
I guess we should know something late next week. If it is a GGT I am not surprised GM is keeping it quite, just in case they are unsuccessful. If it is a QC issue, it must be a significant one that GM would prefer to keep under wraps. Either way, we will likely hear nothing until the cars are released and or invoiced.
Old Feb 6, 2015 | 11:58 AM
MZ06's Avatar
MZ06
St. Jude Donor '14-'15
Obama(EPA) vs GM on the ggt....
Old Feb 6, 2015 | 12:05 PM
CORVETTEZL1001's Avatar
CORVETTEZL1001
Mine should be built in a month hopefully this issue is resolved by then.
Old Feb 6, 2015 | 12:07 PM
mfain's Avatar
mfain
Two questions...Do the M7 deliveries appear to be on track in the last couple of weeks? Also, has anyone who has been to BG seen any activity around the cars being held - like perhaps the rear hatches being opened to gain access to the ECM?
Pappy
Old Feb 6, 2015 | 12:26 PM
BOBSZ06's Avatar
BOBSZ06
http://www.corvettemuseum.org/webcam/delivery1.shtml
Four of eight web cams at NCM show Z06 cars. All M7 cars?
Must be as the A8 is not moving yet.
So....YES M7 Z06 is not being held.
As for activity in the holding lot....anyone have a drone w/camera attached?
Old Feb 6, 2015 | 12:31 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
Weren't there A8 museum deliveries scheduled for next week?
What would happen to those?
S.
Old Feb 6, 2015 | 12:37 PM
denk2003's Avatar
denk2003
S.
I just spoke with my salesman, and he suggested that with normal NCM deliveries, that he usually has the invoice well in advance. He does have one scheduled for next week, and still does not have the invoice. Without the invoice, obviously you cannot complete the final paperwork.
Old Feb 6, 2015 | 12:48 PM
BOBSZ06's Avatar
BOBSZ06
If this "Issue" had to do with a "fix" for something to do with the A8 and relevant items even reprogramming....then why if a car was "fixed" would it be held?
Why not fix a car(s), invoice and then ship...why hold all cars?
And especially for the NCM cars, why would they be held if "fixed".
Still pointing to the GGT.
Old Feb 6, 2015 | 12:57 PM
rgkeller's Avatar
rgkeller
One has to suspect that the cooling solution is not working/well enough.
Old Feb 6, 2015 | 12:59 PM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
Ultimately, the HOLD on the M7 all came down to GGT, and believe it has to be same for A8
Old Feb 6, 2015 | 01:02 PM
C7_Z06's Avatar
C7_Z06
^ Yup. Most likely GGT/EPA issues unfinalized yet, again... round 2.... reminds me of early Dec when our M7 Z06's were held for a bit and then shipped w/ no invoice, etc. When my Z arrived at the dealer on 12/4, I couldn't take it home yet until the invoice arrived... good thing it did that following morning.
Snorman's Avatar
Snorman
This is true. Good point.
The early cars were all at dealers with basically blank window stickers.
S.
BOBSZ06's Avatar
BOBSZ06
If there is a fix and it is being implemented in the recent cars coming off the line for the A8/Z06 then why would these "fixed" cars be held?
As for cooling, the new secondary A8 cooling system was designed and tested before being added to the production cars. And if that is being retrofitted in some way then way not release cars as they are "fixed"....as well as "fixed" cars coming off the line?
Still pointing to the............... GGT.
Old Feb 6, 2015 | 01:19 PM
dcher's Avatar
dcher
This makes the most sense to me. It would certainly be the simplest explanation and seem to fit the facts that are available to us. I wonder if they are still producing A8 Z06s given that they must be running out of room on their lot. Could this be why they seem to be pushing back on the TPWs?
Old Feb 6, 2015 | 01:38 PM
BOBSZ06's Avatar
BOBSZ06
Well, another possibility is that there is some "fix" in the works and it won't be available until late next week. Then the "fix" assuming some hardware item will arrive from a supplier and they can begin the task of retrofitting the cars.
It would seem it must be related to the A8/Z06. Could be anything, so no guesses.
If that is the case then cars coming off the line will have the "fix" and cars in the lot will be fixed in some order.
Time will tell.
To A8 hold extended.
Old Feb 6, 2015 | 01:44 PM
CONMAX's Avatar
CONMAX
i was told by the museum yesterday that the hold is a normal part of a new model introduction. all of the cars are not just sitting. some are undergoing extensive inspections and testing. they could not offer any visibility on delivery because they do not know what if anything is being discovered.
Old Feb 6, 2015 | 01:59 PM
BOBSZ06's Avatar
BOBSZ06
Well, I hope that is all it is as I really question the "new model" theory.
After all the Stingray with the A8 has been in use for months, and there isn't much difference in the Z06, and the Z06 w/M7 has been in use for months. So there isn't much new involved.
Why would continue to hold a car once it has passed the QC checks? Why not invoice and ship once completed? Assuming nothing abnormal was found.
Very confusing.
For an A8/Z06 built three weeks ago, how much testing should be needed as it only involves the A8. And many cars have been built before retail production models with the A8...were these not checked thoroughly?
Old Feb 6, 2015 | 02:15 PM
rob3's Avatar
rob3
Really. The GGT was enacted in 1980 and the current tax schedule was enacted in 2006. Do you remember who was President in 2006???
