RPI Designs APR C7 Z06 Real Carbon Fiber body components
Platinum Supporting Vendor
We are getting more and more calls that GM is having time constraints on supplying carbon fiber Front splitters and side skirts to pre production orders. So instead of waiting for GM, here is a win win, you get the same High quality products at a much cheaper price and you can place the order for your new z06 so you can get it for spring time. Give me a call if you have any questions or would like to place an order 888-257-8515 ext 2. Thanks, Don
Ships Direct from APR, they just need a couple days to ship it out. The Z06 track Front splitter will come with the canards and the undertray with the splitter. Use coupon code RPIDON5 and save 5%
__________________
westman (11-20-2017)
#33
C7 Z06 APR Real Carbon Fiber Body Components
C7 Z06 APR Real Carbon Fiber Front Air Dam Splitter
If you are looking for the best quality carbon fiber to put on your new Stingray then look no further than this APR front air dam splitter. Made right here in the USA, this front air dam splitter utilizes a built in aerodynamic design that creates a high pressure region of air above the protruding surface, which helps reduce lift and increase high-speed cornering. Or course, if you are not into racing, this piece also provides a great visual upgrade over the factory look.
Get your order in today.
Item # FA-207007 $997.95 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4935
C7 Corvette Z06 APR Carbon Fiber Track Pack Front Airdam Splitter
Our C7 Corvette Z06 real carbon fiber track pack front splitter is the ultimate for your C7 Z06. This front splitter is made of 100% carbon fiber, is extremely strong and very lightweight. If you are serious about your C7 Z06, this splitter is for you. Not only does it look great, but functions better than any other performance splitter on the market.
Item # FA-207028 $1,705.25 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5451
C7 Corvette Z06 APR Carbon Fiber Side Rockers Skirts
If you are looking for the best quality carbon fiber to put on your new Stingray Z06 then look no further than this APR C7 Corvette Stingray side rocker extensions kit. Made right here in the USA, this side rocker kit helps reduce under-body turbulence, lift and drag by limiting excess airflow to the under- body. Or course, if you are not into racing, this kit also provides a great visual upgrade over the factory look.
Item # FS-207028 Price $1,610.55 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5214
C7 Corvette Z06 APR Carbon Fiber Rear Spoiler
If you are looking to give your C7 Corvette Z06 a fresh, bold look, then look no further than our APR Performance real carbon fiber rear spoiler. This spoiler is made of 100% carbon fiber and comes complete with the wickerbill as shown in the photo. UnLike the factory GM wicker bill that is non adjustable, this one can be adjusted 7/8's of an inch. This spoiler is not only designed for great looks, but will also perform as it was intended. This spoiler bolts right up to a C7 Z06 Corvette.
Item # AS-105757 $1,187.00 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5447
C7 Z06 Real Carbon Fiber Lower Diffuser
This C7 Corvette Stingray real Carbon Fiber Rear Diffuser is a direct replacement of your existing diffusor. Made in the USA by APR.
*Rear diffusers help reduce turbulence of the under-body airflow that exits the rear of the vehicle. This helps to reduce both lift and drag
Item # AB-277019 Price $1,465 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4971
C7 Z06 Real Carbon Fiber Side View Mirror Housings- set
These C7 Corvette Stingray Carbon Fiber Mirror Housings are very light weight and replace your existing mirror housings.
This mirror conversion kit replaces the factory mirror housings (but re uses the existing lenses and power mirror mechanisms).
Item # CF-207007 Price $665.00 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=4970
C7 Corvette Z06 APR Carbon Fiber Front Fender Vents
Give your C7 Corvette Z06 the very best treatment with these replacement carbon fiber front fender vents. These front fender vents are made by APR Performance and designed to simply replace your existing OEM GM plastic vents. Once you get these new Z06 Carbon Fiber vents installed, just transfer your Z06 badges from your old plastic pieces to these new carbon fiber pieces. These C7 Z06 front vendor vents are sold as a pair. Free ground shipping on these vents.
Item # CF-700802 $650.75 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5449
C7 Corvette Z06 APR Carbon Fiber Hood Vent
Here is a great way to set your C7 Corvette Z06 apart from the crowd. This real carbon fiber hood vent is a direct replacement of the existing plastic hood vent. Simply remove your plastic hood vent and replace with this carbon fiber hood vent. Built to be the exact same shape and size as the OEM GM unit. This hood vent is clear coated for a high gloss, show winning shine.
Item # CF-700805 $565.25 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5448
C7 Corvette Z06 APR Carbon Fiber Rear Quarter Panel Ducts
These C7 Corvette Z06 carbon fiber rear quarter panel ducts are a great match to our front fender ducts shown to the right side of your screen. These rear quarter panel ducts are made of real carbon fiber by APR Performance and designed to simply replace your existing ducts. Installation is quick and easy. These quarter panel ducts are sold as a set of two.
Item # CF-700804 $ 650.75 use coupon code RPICHRIS5 on line or by phone and receive 5% off the listed price !!!!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=5450
#36
Hi,
I believe you will find that here: https://www.rpidesigns.com/shop/item.aspx?itemid=5472
Thanks,
Chris
Thanks,
Chris
#37
Thanks for checking us out!! Use Coupon Code RPICHRIS5 for immediate savings!!!
#39
I received the partial order from APR Performance in good condition. I was preparing to install the APR Carbon Fiber side skirts on my 2018 Corvette Grand Sport but was concerned when looking at the APR installation instructions. Pictured is a C7 Stingray throughout the installation rather than a C7 GS or C7 Z06. I ordered the Track Pack for a Z06 but I am a bit concerned that I may have received a C7 Stingray Track Pack instead. Before I commit to the installation by removing factory components, I need to talk to someone that can explain if there are differences between the Stingray side skirts and the Z06 side skirts??? I know APR makes and sells track packs for both the C7 Stingray and the Z06. My Corvette GS came with the factory Stage 1 side skirts and it appears their are differences from what is pictured in the APR instructions. In fact the images in the instructions are too dark to help with visualizing what is supposed to be done. For example, my factory side skirts are attached with a few bolts and what looks like some sort of rivet. The APR instructions mention none of this or do they show how to remove the factory side skirts. It looks to me from the images in the instructions that this kit I received is for a Stingray with no factory aero installed. Needless to say, I am confused about what was actually shipped to me from APR. I need to hear back from either RPI or APR as soon as possible. Thx!
Last edited by B2Vette; 01-05-2019 at 04:11 PM. Reason: Add additional information
#40
Give us a call at 888.257.8515 ext 2. Paul should be able to help you out with that.
Let me know in a PM if you have any further trouble.
Thanks,
Chris
B2Vette (01-07-2019)
