Headlight gap issue
After inspecting the car the third time and refusing to sign off on it, they called GM and ordered a new headlight unit to see if it would fix the issue. It helped, but there is still a noticeable difference IF you know to look at it. The dealership told me that once the nose of the C7's are taken off, it is impossible to get them back to the factory fit. I wonder if for any reason the dealer had removed the nose of the car prior to you taking delivery? It definitely sounds like something happened if there are scratches as well.
Now, to make you feel somewhat better, I finally had my Z06 order get picked up by GM and between this order and my Z51 purchase, I have looked at literally a hundred or so C7's. Almost every one of them, all brand new cars, have gap variances that differ between the two headlights. They might be small, but I found it was a consistent issue.
I would get with your dealer and ask them to warranty claim a headlight and see if that reduces the difference. It worked for me on the fourth try. I hope it works out for you.
