Wicker Bill Installation Help Needed
Old Mar 9, 2015 | 02:03 PM
Ftmyersgt's Avatar
Ftmyersgt
Default Wicker Bill Installation Help Needed
Any tips on installing the four rubber grommets during the wicker bill installation? Grommets are numbered for specific location and are to be mounted on backside of the wicker bill, but grommets do not stay in place. What am I missing. Thanks.
Old Mar 9, 2015 | 02:10 PM
JackTripper's Avatar
JackTripper
Turn 12!
I will try to find the dealer instruction sheet, I kept it. I will post it when I locate the document.
Old Mar 9, 2015 | 02:12 PM
WilliamCall's Avatar
WilliamCall
I put a couple of drops of superglue on the grommets to hold them in place. In retrospect, I should have used a rubber cement or silicon caulk to hold them in place.
Old Mar 9, 2015 | 02:26 PM
Ftmyersgt's Avatar
Ftmyersgt
Have the instructions, but the grommets won't stay in place. I'll try a small piece of dbl face tape.
Old Mar 9, 2015 | 02:58 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
This is what I did.
Ftmyersgt's Avatar
Ftmyersgt
Default Thanks to those that responded!
Got it! Used short thin strips of 3M trim tape at tops and bottoms of grommet groove to hold grommets in place until bill was fastened with screws. Worked great.
To Wicker Bill Installation Help Needed
