Sponsored by: GEM Motorsports
New Z06 Underhood Kit
Old 01-22-2019, 03:03 AM
  #421
C7/Z06 Man
C7/Z06 Man's Avatar
Default Owner could do it at home on the car.
Originally Posted by Pete@Showstopper
This kit includes a total of five covers to clean up the look of your engine compartment. Each kit includes a fuse box cover, master cylinder cover, surge tank cover, abs unit cover, and sensor cover. A wide variety of options and finishes are available.
Here are a few sample pics to give you an idea.
Does anyone make a decal that would stand the heat that looks like the 'top' pic coil cover one above? That one would work with any color car because it matches well with the OEM coil cover color & supercharger lid.
The owner 'could' also spray the coil cover and decal with a coat or two of hi-temp clear from a spray can for that professional look.
PS: "Sometimes Less Is More" OR my saying: Keep it Lean, Clean, and Mean.
Old 01-22-2019, 08:49 PM
  #422
Pete@Showstopper
Supporting Vendor
Pete@Showstopper's Avatar
St. Jude Donor '14. '17
Originally Posted by rsmith4604
That's the one I need. I have a 2018 Torch Red with Black accents Z06. Please send me prices and ordering info.
Thanks for the order.
rsmith4604 (01-23-2019)
Old 01-23-2019, 09:40 AM
  #423
rsmith4604
rsmith4604's Avatar
Your welcome, Peter. Thanks for your patience in working with me to decide what to do. It's gonna be a show stopper!!!
Old 01-24-2019, 05:02 PM
  #424
eaglesnick
eaglesnick's Avatar
A close up
If I wanted to order the covers in post 391 with the base being black and the caps in post 407 in black as well what would the cost be and how would I go about ordering?
Old 01-24-2019, 11:14 PM
  #425
Marc DeSatnik
Marc DeSatnik's Avatar
pm a price for a set like this
marc
Old 02-05-2019, 07:50 PM
  #426
Pete@Showstopper
Supporting Vendor
Pm me for package pricing.
Old 02-20-2019, 08:43 PM
  #427
Pete@Showstopper
Supporting Vendor
Old 02-26-2019, 02:48 PM
  #428
Pete@Showstopper
Supporting Vendor
Old 03-07-2019, 08:15 AM
  #429
c7steve
c7steve's Avatar
how is everyone putting there driver side coil cover on? i have some covers that pete is going to be painting. i removed the driver side but i dont see it going back without scratching it.
Old 03-07-2019, 08:57 AM
  #430
Panth3r
Panth3r's Avatar
Are these plastic??? This would look cool if I could match my wheels powder coated color (Illusion Cherry)
Old 03-07-2019, 09:52 AM
  #431
rsmith4604
rsmith4604's Avatar
I have a set ordered for my 2018 Z06. The only mention I've seen addressing scratch protection is covering them with painter's tape. When I do this to mine, I'm hoping the paint doesn't peel off with the tape. The other worrisome problem is the PCV valve removal without breakage. They say......run the engine until warm and twist 90 degrees clockwise pulling out. I'll see when mine get here. Good luck
Old 03-07-2019, 10:00 AM
  #432
jstewart
Support Corvetteforum!
jstewart's Avatar
Pete shoot me a price for the pieces in post 328 (torch red, same detailing) for my 2016 Z06 auto trans. Also for a set of fluid caps to match. Please list pieces quoted.
Old 03-07-2019, 12:38 PM
  #433
ahero4eternity
ahero4eternity's Avatar
Finally got around to installing my goodies.
Old 03-07-2019, 12:43 PM
  #434
c7steve
c7steve's Avatar
did you remove braided line to install driver side coil cover
Old 03-07-2019, 01:41 PM
  #435
LouD
LouD's Avatar
I used self adhering film like the kind movers use to wrap furniture, etc. You should cut a piece of film to fit the shape of the cover edge-to-edge as close as you can without overwrapping the edges. If you overwrap the edges, film removal will be difficult once cover is in place. With cover in place remove film before securing. If you don't have access to mover's film any similar film material will work, eg., several layers of "Cling Wrap" or "Press n Seal". I would not recommend using painter's tape.
rsmith4604 (03-08-2019)
Old 03-07-2019, 02:38 PM
  #436
Meister Vette7
Meister Vette7's Avatar
Had my Assistant (aka wife) help with the driver side re-install to keep parts from scratching. Just move as much of the piping, etc. as you can out of the way and go slow. I didn't scratch anything putting them back and didn't use protective tape. The PCV valve comes out fairly easily if warm enough. Just heat it up a little with a heat gun or even a hair dryer and twist it clockwise like mentioned. Just be patient with it and don't pull with too much force if it doesn't want to move right away. I was worried with this too but it wasn't a big deal.
Old 03-07-2019, 03:21 PM
  #437
c7steve
c7steve's Avatar
i just removed both covers finally, i dont see how they can go in even slowly without scratching them,, anybody remove part of the back plastic before paint ?
To New Z06 Underhood Kit
Old 03-09-2019, 07:41 AM
  #438
Pete@Showstopper
Supporting Vendor
I usually recommend putting painters tape on the covers while installing. This works like a charm.
rsmith4604 (03-09-2019)
Old 03-09-2019, 09:24 AM
  #439
c7steve
c7steve's Avatar
the problem i see is the back part of covers on both sides do not flex at all ,
Old 03-09-2019, 09:30 AM
  #440
rsmith4604
rsmith4604's Avatar
LouD at reply #435 would not recommend using painter's tape, but here's "the Man" Pete, who creates these beautiful additions to your engine compartment, telling us to always use painter's tape. Pete.....is there any chance of the tape peeling the paint off your products? Thanks for clearing this up, Pete.
Quick Reply: New Z06 Underhood Kit
