HPDE Prep
Old Mar 31, 2015 | 10:24 AM
jdmdohcpower's Avatar
jdmdohcpower
Default HPDE Prep
SO I booked 4 dates for track time after I return from Z06 school in Vegas and I want to make sure I have everything right for the car.
at that time I will have 1500 miles and I was told I should change the diff fluid. Im not sure why unless there is a break in on that also. Can anyone recommend a fluid?
sharkbar and harness's are in
will bed the brakes before going
tire pressure to 27-28psi (if I really dig it and plan to do more Ill get spare wheels with cups 2's)
the car is bra'ed but I was thinking about the novistretch bra for more protection. Will this restrict air flow too much?
Anything else?
Old Mar 31, 2015 | 10:32 AM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
I am not sure that a Novistretch bra will pass tech. Tire pressure is going to be dependent on temps but the general consensus is 30-35 psi HOT. You can start in the 27-28# cold range and adjust from there. Follow GM's recommendation for 15w-50 oil for track use and consider a track alignment.
S.
Old Mar 31, 2015 | 10:36 AM
jdmdohcpower
So change the oil before I go and again when I get home?
Old Mar 31, 2015 | 10:40 AM
Snorman's Avatar
Snorman
Have you already put 15-50w in it? Factory fill is 5w-30. If you've already changed it to 15w-50, and it has relatively low miles on the oil, you should be good to go.
However, contrary to what some may do, I change oil before every track event 90% of the time.
S.
Old Mar 31, 2015 | 10:49 AM
jdmdohcpower
have my 500 mile service on sat..
Old Mar 31, 2015 | 10:52 AM
Snorman's Avatar
Snorman
I guess it depends on when you are registered for your first track event. If it's several months from now you might want to stick with 5w-30. If it's soon, maybe switching to 15w-50 is a good idea now.
S.
Old Mar 31, 2015 | 11:17 AM
thebishman's Avatar
thebishman
Think about getting Clearplex on the windshield. They can really take a pasting on track. When track season is done, remove the Clearplex and viola, pristine windshield again.
Have fun.
Old Mar 31, 2015 | 12:04 PM
seamus2154's Avatar
seamus2154
Have fun.
How much are you paying for the clearplex?? Thanks
Old Mar 31, 2015 | 03:17 PM
Kvettetrk's Avatar
Kvettetrk
The manual recommends changing the diff fluid after the first track event.
Consider dot 4 brake fluid. 15w50 with .5 l more oil over the standard fill.
Track alignment.
Anything else?
Old Mar 31, 2015 | 04:01 PM
thebishman's Avatar
thebishman
It can vary widely but I can have it installed for around $250 locally.
Old Mar 31, 2015 | 06:28 PM
Babaron's Avatar
Babaron
Is there any problem with doing the track alignment, then driving 120 miles to the track?
I don't think I have much of a choice. Just wondering what effects on the car/tires will be.
Old Mar 31, 2015 | 07:05 PM
jdmdohcpower
Tires will wear a bit faster but if you do a few track events it's worth it. I don't put more then 3 or 4k on my car a year so I'm not worried about street wear
thebishman's Avatar
thebishman
None IMHO as I'm willing to accept a moderate increase in inner tyre wear for the more responsive handling. Once I'm past break-in I'm getting the track alignment and will run it 100% of the time.
Bish
Old Mar 31, 2015 | 07:40 PM
63Corvette's Avatar
63Corvette
Depends..........Toe is critical for tire wear, Run ZERO toe (in front) and you should be fine.
Old Apr 1, 2015 | 10:10 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
The track alignment will work great on the track but make your car a bit jittery on the street. I just deal with it (on my GS).
Do you have CC brakes? What color are your street wheels? Burnishing the CC brakes will put a layer of brownish crap on your wheels that will look like you've burnt them. It will come off but not without some serious elbow grease.
Old Apr 1, 2015 | 10:12 AM
jdmdohcpower
My wheels are black and ceramic coated so I don't expect it to be to bad to come off
To HPDE Prep
