Has anyone measured the ground clearance with the OEM Stage 2 front splitter installed? Anyone know the difference in ground clearance compared to the Stage 1 splitter?
Do not have exact measurement on Stage 2, but Stage 1 splitter clearance is 6 inches on stock Stingray. May be lower depending on the suspension.
The Stage 2 splitter should be close to the same, but remember that the more it extends ahead of the wheels, the more likely to drag, even with the same vertical clearance.
Do not have exact measurement on Stage 2, but Stage 1 splitter clearance is 6 inches on stock Stingray. May be lower depending on the suspension. The Stage 2 splitter should be close to the same, but remember that the more it extends ahead of the wheels, the more likely to drag, even with the same vertical clearance.
Thanks. I really like the Stage 2 ground effects package, thinking carbon flash, but my last splitter experience on a lowered C5 didn't end well.
My Stage 2 is 5.75" to the bottom of the splitter, stock factory ride height.
