Hardbar makes/sells a nice, robust and easy to install/remove bracket for the passenger seat rail on C6s. I don't know if they have out yet for the C7, but you might check with Hardbar and see.
The seat rails are different on the C7. However, the ones that mount to the front seat bolts (under the seat rails) are the same spacing. I just helped install one on a C-7 Z-06. Vetteworks has them for sale.
Yeah, I figured they were different, that's why I mentioned he should contact Hardbar and see if they are making any yet for the C7.
I had the Brey Krause mount for my C6. I believe it's even the same one they used on the C5. It fits the C7 bolt spacing, but is a bit tight to the seat. It works though, I've used it.
Hardbar has them in stock thanks they are great to work with
