Tow hooks
Old Apr 21, 2015 | 11:01 PM
hookem79's Avatar
hookem79
Default Tow hooks
Bought some nice tow hooks. Went to put the front one in and there are no threads in the slot for the hook. Has anyone else had this happen?
Old Apr 21, 2015 | 11:23 PM
2vettes's Avatar
2vettes
No, my tow hook screws in perfectly. Not something I'm leaving screwed in. Under the carpet in my trunk is the indentation for the tow hook, so I keep it there.
Old Apr 21, 2015 | 11:40 PM
BEZ06's Avatar
BEZ06
What hook did you buy???
The forum wisdom is that all C7 Z06's have been built with the threaded receiver in place.
If you got the OEM hook it should screw in.
There is a nice aftermarket hook by forum vendor ZL1 Add-ons that also has the proper thread size:
http://www.zl1addons.com/index.php/s...ow-hook-detail
If you got some other aftermarket hook that doesn't have the M20x2.5 threads, then it won't screw in there. Many aftermarket hooks may have threads, but they are usually MUCH smaller than what is required, and they will go into the receiver and seem like the receiver isn't even there.
Or, it could be that you have a Z06 that didn't get the threaded receiver installed as it came down the assembly line like apparently all others did.
Old Apr 22, 2015 | 12:34 AM
golfnutintib's Avatar
golfnutintib
mine screws in properly (its the heavy black cast iron stock one)... sounds like you bought the wrong one
Old Apr 22, 2015 | 01:09 AM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
Take a photo of it and let's see it?
Old Apr 22, 2015 | 01:14 AM
v jet's Avatar
v jet
Got my OEM hook too, it works and I placed it in the rear storage indentation for when I may need a tow.
Old Apr 22, 2015 | 04:47 AM
WilliamCall's Avatar
WilliamCall
I had a burr at the threaded opening that prevented me from screwing the tow hook in. I borrowed a M20x2.5 tap and carefully started the tap, which removed the burr. Problem solved, tow hook screws in as it should. Double check and see that you don't have something that prevents you from engaging the first few threads of your tow hook.
Old Apr 22, 2015 | 10:48 AM
shockwave's Avatar
shockwave
As long as it is a Z06 there should be threads there. Non Z06's do not have threads or receptacle for tow hooks that I am aware of.
Old Apr 22, 2015 | 08:09 PM
hookem79's Avatar
hookem79
So there are no threads in the front. The rear threaded hole is smaller than the tow hook I bought from ZL1 addons. Don't get me wrong these tow hooks are great. This is a GM thing. Suggestions?? I plan to call the dealer tomorrow
Old Apr 22, 2015 | 11:08 PM
firstgear's Avatar
firstgear
St. Jude Donor '15
I would check the diameter of the hole and it might be as easy as running a tap in if you can do it straight......cut your own threads....or maybe the diameter isn't correct as the entire machining process was left out.
Not sure how that is attached, but I have to believe that it is buried into the structure in some form or fashion......share what you find out !
Old Apr 23, 2015 | 12:14 AM
BYBY4RE's Avatar
BYBY4RE
The front is threaded behind the plastic you can see in your pic. To thread the hook in you need to bend the grill up probably a half inch. I had the same issue as you. Give it another try.
Old Apr 23, 2015 | 12:35 AM
dvandentop's Avatar
dvandentop
It is good to run a tap and die on the stock tow hook because the paint on them makes them very difficult to screw in the first time
Old Apr 23, 2015 | 09:49 AM
hookem79's Avatar
hookem79
ZL1 addons said the same. I'll give it another shot
Old Apr 23, 2015 | 02:00 PM
Skylane765's Avatar
Skylane765
Supporting Vendor
I shipped one tow hook for the front or rear that did not have the threads chased. If anyone has it just call me and I will send replacement right away. The threads are all undersized about .015. One I shipped that did not have the chrome chased off.
To Tow hooks
