AFE Intake vs Halltech
Old May 14, 2015 | 12:18 AM
shftn7's Avatar
shftn7
Default AFE Intake vs Halltech
Has anyone ran the numbers on the dyno to see the difference?
Old May 14, 2015 | 12:41 AM
dvandentop's Avatar
dvandentop
these barely started shipping give it a month or 2
Old May 15, 2015 | 12:03 AM
shftn7's Avatar
shftn7
i wanna see if there is a $1000 worth of performance thats all.
Old May 16, 2015 | 08:49 AM
Blvdbrawler's Avatar
Blvdbrawler
Will be good battle...I think both are good but I went with Halltech!
Old May 16, 2015 | 09:06 AM
thegeneral101's Avatar
thegeneral101
Looks like the afe guys are having trouble installing. Halltech addressed the coolant hose already and install is smooth. Glad I went with halltech.
Old May 16, 2015 | 10:20 AM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
In the end I believe that you will find both equally as good. Some dyno runs will be higher than others but in the end, they both reduced the amount of restriction and flow more air....
I went with the Halltech carbon fiber version strictly because I think it adds to the engine bay looks with functionality at no extra cost.
I was considering the Callaway modification, but appears to provide only 50 more hp for an extra $16k.....the cost to benefit ratio doesn't work.
When my warranty is past, DeWitts radiator (2x passes), lower thermostat and tune will be the way to go. The three above go hand in hand to getting lower engine temps but then they will void your warranty should something ker-plunk and should find a few more ponies....
To AFE Intake vs Halltech
