What does the winglets do ?
I would like to know from having no winglet to using the large winglet how much drag and downforce it produces. In order to determine at specific tracks what would be the best winglet combination to use, and wha the combination between the winglet to rear spoiler will produce. Maybe asking for too much.
Doug
The amount of downforce you would get on the few square inches of splitter in front of the wheels, from induced high pressure probably amounts the weight of about two hamsters.
Everything possibly is being done to keep air out from under the car, the side skirts keep air that is spilling down the sides from sucking underneath, by blowing the air outward, the winglets likewise keep air from under the car, and also i believe, reduce drag, by keeping more air away from the sides. The mechanism that does this is easy to illustrate, but hard to explain, I am aware of this effect from research done on semi trucks a few decades ago.
That rear spoiler, doesn't act so much as down pusher, it is too small, what it does do is throw turbulent air further behind the car,and also creates more vacuum immediately behind the car, which creates suction underneath.
Everybody blames the aero for more drag, but i would suggest the stage 3 reported reduced top speed may not be from increased drag, but increased tire rolling resistance due to more applied down force. probably why GM suggests higher tire pressures for long high speed runs.
Everything I look at tells me the stage 3 should have less aero drag than stage 1.
As a side note, that rear panel with the vertical vanes that WeaponX sells, possibly helps creates more downforce than the factory panel does.
Doug
I like stage 1 and no winglets easier not to worry about them
Doug
forcing air OVER the car instead of under it does create a downforce. that's exactly what they were going for. you say its a pisspoor way of getting it done but I'm not sure there is any other way. That's specifically why splitters and wings (and spoilers) were created. Yes, it does create drag and it makes the tires harder to roll with the extra downforce. That is a tradeoff that can't be avoided.
I think.
Ever see how an airplane wing works?
Air underneath the wing, doesn't lift the air plane, vacuum from faster flowing air above the wing lifts the airplane, even though high speed air is pushing *down* on the front of the wing.
Wouldn't you intuitively say that air should push that hump down,a s it hits the front and tries to force it down when it goes over? It works the opposite.
You can put giant upside down wings on cars and they work the same way, an upside down airplane wing, but they are huge drag makers, so we don't want to do that for CAFE reasons
You want the reverse in a vehicle, you want vacuum under the car. You get a lot of that from a Bernoulli effect, with a smooth surface underbody. http://www.cdxetextbook.com/assocStu...principle.html
Look at those big *** tunnels on the rear of an Enzo Ferrari, they create vacuum under the vehicle to get downforce, Enzos don't get downforce by blasting air onto wings and spoilers. The Enzo doesn't have squat for a spoiler, but it has around 800 lb downforce.
.Doug
