View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#5201
I am sure you all heard about this Class Action filed June over the overheating. Just in case, here is an article .....
https://www.hbsslaw.com/cases/corvet...g-on-the-track
BlackMoon (09-05-2017)
#5202
Summarize Options
I am an owner of a 2008 C6 Z51 M6 and track my vehicle a few times each year.
I am looking at upgrading to a C7 Z06 M7. In trying to understand my options, I read through and searched this thread. I did some internet searches. Lastly, I read through the LG Motorsport cooling system thread. Below is my understanding of my options if I wish to continue to track with a Corvette. Will anyone confirm if my understating is correct please?
1. Do nothing and stick with my C6 as it is still a ton of fun
2. Purchase a 2015-2016 Z06 M7 leave the super-charger alone. Get the GM retro fix installed and count on needing to do one the following in addition to the GM retro fix:
a. Purchase LG Motorsport cooling package: https://www.lgmotorsports.com/corvet...k-package.html
b. Purchase the GSpeed cooling package: https://gspeed.com/product/c7-z06-cooling-stage-ii/
3. Purchase a 2015-2016 Z06 M7 and use a after market shop like Lingenfelter to switch out the supercharger (not sure which of these packages I would need): http://www.lingenfelter.com/category...4_2015-16.html
4. Purchase a 2017-later Z06 M7 and hope that I am a cruddy enough driver to not push it to the overheat limits or that I am one of the lucky ones where it doesn't over heat (from what I understand these two are not independent).
5. Purchase a C7 Grand Sport and go with a package like the Lingenfelter ones listed in option three.
Is my understanding correct or am I
#5203
From what I read you are right, but check with more people before you get the car to be sure.
I kept hearing grand sport is way better track car than z06 though, way easier to track something that z06's chassis can't handle the HP. z06 does faster laptimes but much harder to drive I guess.
What I want to know is what % of 2017 M7 will overheat, so far it seems to be very few?
#5204
#5205
cool thanks for the info
#5206
Rather than join a lawsuit regarding overheating on the track that enriches attorney's and will not settle for years, read your owners manual about disputes. First document overheating on the track with your PDR. Take the information to a couple of dealers and have them document there is not fix. Write to GM who will blow you off. Then as indicated in your owners manual file an online claim with the BBB. This is the only way to resolve a real issue.
#5207
Location: Louisville Ky NCM Lifetime Member 429 (Member Since 1993)
St. Jude Donor '12-'13, '16
Mine overheated today driving on the street
My 2016 z06 A8 overheated 4 times in about 45 minutes of in town and highway driving. Never pushed the car hard (45-55mph) and the outside temp was 81 degrees. The message from the dash was engine overheating, turn off a/c, and then engine overheating,, idle engine. I did figure out my water temp gauge wasn't working (it was stuck on about 130 degrees). My oil temp reached 245 degrees. Also, my fan doesn't normally stay on after the car has been turned off. But today, it was staying on for several minutes after the engine was turned off. I have about 7,000 miles on it. I had to stop the car 3 times due to heat while I was trying to get to the dealer.
they are going to look at it tomortow.
#5208
#5209
is there a way to test to see if your car will overheat at the track? awhile ago someone posted the testing methods but I couldn't understand it, it wasn't clear.
#5210
262 is when the car over heats. 220 is nothing, car will run like a raped ape at a 220 coolant temp. What is your oil temp that is more important than coolant temp. That should be less than 300.
On track in low 90 degree heat I see mid 220 coolant temps and mid 270s oil temps. Car runs fine at those temps.
Bill
Bill
#5211
Your issues probably can be corrected. The real issues come with aggressive tracking done by maybe 2% of the owners. The 2% of the cars that overheat on the track currently don't have a solution. If the dealer can't correct after a couple of attempts file a complaint with the BBB as instructed in your owners manual.
I sure the hell expect it to be resolved and it should have not happened in the numbers being reported. I am dismayed that I can take my car to the largest corvette dealership in the region there doesn't appesr to be good direction from GM to diagnose the root cause of rhis issue. The car isa not cooling correctly at 45-55 mph, and leaves me to stop several times within a mile of highway driving at these speeds with no traffic? I ended up only being able to drive the car in the emergency lane with hazard lights on or it overheats. That's just so wrong on so many levels.
The car has less than 7000 miles on it and right now it could be out run by a moped.
Don't be so quick to write off my issue. I paid $100k for this?
A e are now 3 model years in and something like this occurs (and it is apparently happening more than anyone from GM or some defenders here want to admit) there should be definitive TSBs that setvice departments have to diagnose and resolve the most common causes. The dealer said initially that their appears to be air in the intercooling system, and they asked me if I had done anything to it? Didn't Tadge say one of the problems GM found in cars overheating was improper bleeding of the intercooling system at the factory? The dealer can't figure out the source of the air in the system.
I guess I will have to tell them about tadges statement. My question is why this would take so long to show up to be an issue? Shouldn't the coolant level be low and have been low for a long period of time? If so, why wouldn't the low coolant level had not been found during normal maintenance ( the oil waa last changed May 31st).?
The car went into the dealer Thursday and kept it over the weekend. I am supposed to go to Bowling Green next. Due to my health, I can not risk being stranded on the side of the road. I am seriously considering not going, because I am concerned I can not trust the car.
it's a damn sad situation.
#5212
Has anyone else experienced this.......... as mentioned above my last oil change was on May 31, 2017.
- Right now, I have put less than 1,000 miles on the car since the oil change.
- On my August Onstar report, my oil life was listed at 85%.
- When I took the car in for overheating last Thursday, oil life was 0%. (and the oil level was fine and the oil was clean on the dipstick).
Anyone familiar with this?
#5213
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
#5214
As part of the repair of what ever is causing your over heating (its not normal) a oil change should be done.
#5215
Engine temp is one of the factors the system uses to determine remaining oil life. Depending on how hot and for how long, its entirely possible the overheating event used up the remaining oil life according to the calculation it used.
#5216
I got into Fontana CA earlier today.
116 degrees!
Good to know that I don't have to worry about overheating this weekend at Optima in Fontana CA. autoX tomorrow and speed stop and road course Sunday. I'll let everyone know what happens. Lol
116 degrees!
#5217
I just returned from Ron Fellows Performance driving school yesterday. I was driving two different Z06s with A8 automatics. We would drive in manual mode only using gears 3-4-5. It was very hot 106+. I really pushed my cars hard during the lapping (2 instructors told me they liked having me behind them) Neither day did either of the cars overheat and I was watching temps. Don't get me wrong a couple of times the oil temp approached 235 as I slowed down to come in, but never when I was at speed with air flow through coolers. Now they are running 15-50 weight Mobil 1 and I don't know if they were running higher octane gas which would help tremendously. I also will say those Z06s had no where the power my Florida based (sea level) Z06 has at 95 degrees so performance was significantly degraded.
#5218
I never identified which facility it was and never proved it one way or the other, but the ZR1's I drove definitely didn't perform the same as my own. I still have it, .
mjdart (09-03-2017)
#5219
My last time at Spring Mountain I had ambient temps in the 80's and was getting very close to limp mode on water temps... had to shorten our sessions to allow cool downs. Water was up in the 250's and climbing... 262 is limp mode threshold. I have never had my car shut down for oil temps... I've hit 290's (just shy of 300 a couple times) but water always seems to trigger first before oil climbed over 300.
It only takes a lap or two of "lighter" driving to bring temps back into more reasonable range, so those lead follow laps, with driver leapfrogs on the back straight, give the cars time to stay well within temp range MOST of the time.
mjdart (09-03-2017)
#5220
Spring Mountain very tightly "controls" what you do (drive mode, gear selection, shift points, speeds, session lengths, etc.) all of which help to manage heat issues. When you start doing open lapping (Level 1 Day 3 or Level 2 Day 2) or if you do private sessions where you're basically running at your max abilities and begin to push the car's upper limits for repeated laps, you'll see heat issues appear.
What do they charge for private sessions?
