View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#1061
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Those who are concerned, should be asking the tuner shops that post in this section about how well the C7Z dynos once it gets hot. Say, doing 3-4 consecutive dyno pulls without turning off the engine or letting it cool. They are so focused on the max (cool) numbers to share with you, but they aren't mentioning the hot numbers. Two local guys, one dropped 20 rwhp, the other dropped 28 rwhp. I wonder what the other shops are finding, but won't talk about.
Originally Posted by sdtoothdoc View Post
Great work over there guys. Have you noticed any reduction in power with back to back runs...any issues noted?
As you can see from the graph we are having no issues with power reduction... We made three pulls back to back to back and actually made more power with each pull
That being said, we are obviously not working with the OE calibration file.
#1062
Premium Supporting Vendor
3rd pull without cool down/203 degrees coolant 549 rwhp
Not suprising and definitely not just a C7 Z06 issue as most every supercharged car and most NA GM cars lose 2-5% est. after 3 back to back dyno pulls
#1063
Owning a Z06 does not make "one an expert"!
Are the stories not true? Here's the chance for the "actual owners" to speak up! Let's run your Z06 with my ZR1 for some three honk action! I hear tons of people opinion's on those too and they never been in one.
I figure if I just get a mint shape used Turbo S the ***** contest is over.
(I like to buy used more car for the dollar) Those cars come out hard then manage to out run about anything!
#1066
The 595 number we saw is one happy dyno.
So the rest of the numbers are too!
then after 3 pulls it's ZR1 numbers with C7's the extra weigh and
drag.
#1067
How does doing dyno pulls at 170 degrees and 203 degrees reflect the horsepower when doing real world driving(or doing multiple pulls on the highway) with the coolant running 220+?
My 2009 Z06 runs 192, right on the thermostat's setting. I seem to remember that the PCM doesn't start pulling timing until the coolant temp reaches 213 degrees
At what coolant temp does the C7 Z06 start pulling timing?
#1069
ZR1 with 12% driveline loss is 561HP and that is reflective of what they dyno. Not the 530HP that the same shop that posted the 585HP for the C7 Z06.
#1071
Regardless using the diminished Z06 numbers compared to the 561 number for the ZR1 you are still missing about 50ftlb of tq in the ZR1. Which will more than offset the weight penalty for the Z06.
These cars should perform roughly the same with the Z06 being slightly quicker out of the whole or corners because of its tq advantage. Once at higher RPMs the cars are nearly identical and should hold position. This is if you believe only the Z06 loses power. If you believe they both lose power then the nod certainly goes to the Z06.
#1073
Preference
It's all purely preference. It's like asking what the best colour is.
I currently own a 2014 911 C4S, but have a Z06 on order. I spent 5 days recently at the Springmountain Motorports park driving the C7's. The experience was impressive enough to go down the road in getting a C7 Z06, but they are very different cars.
Porsche makes an incredibly well built, ergonomically correct fun car to drive! I constantly find excuses to drive the car. The PDK transmission far exceeds my expectations. It is a smooth and deceptively fast car considering it only has 400HP. The grip will put a smile on your face every time you have a chance to test it. That being said; they are not cheap! Every option is overpriced.
The reason I decided on the Z06 was the amount of fun it is per $$ based on the fun I had tracking a C7 in September. The plan is to keep the Porsche when the Z06 eventually arrives. I can see the Porsche being the car for longer trips...
Good luck in your decision. They are both great cars, you cannot lose either way!
#1074
Why does it bother you now that the C7 Z06 has only 99% of its cold weather performance when hot?
#1077
There is no precedent for a car so heavily marketed as having x amount of hp and y amount of torque that can only deliver that power for short bursts of time.
GM will fix this, I have faith in them. But burying your head in the sand and making ridiculous excuses for what is happening now does NOBODY any service.
#1079
This is an absurd argument. I don't think Foxer55 would expect to get 100% of the performance in the snow either.
You concluded the Z06 is broken now? Show me your evidence. I just think you have nothing to show for your claims. Do you expect GM to recall a vehicle because one journalist found a small fault with it and nobody was able to replicate it?
When you hear a squeak and you take your car to the dealer, do they fix it without replicating the squeak?
Show me the Z06 is broken. You have no concrete evidence.
