View Poll Results: If you've Overheated What is Your Stage Aero 1, 2 or 3
Voters: 348. You may not vote on this poll
ZO6 overheating issues ***MEGA Merge***
#1621
Um...that car does not have the LT4 SC motor. And the vents are likely there in large measure to reduce lift in the front end. They have nothing to do with "..this car..", meaning the C7Z06.
#1623
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
I will say this, the only "cooling" mod I've done to my ZR1 was add a hood vent instead of the window and when I pull off the plastic engine shroud/cover on the track, I did notice a cooling improvement, possibly as much as 5-10F for coolant/oil temps. I guess a ton of heat circulates around the engine and out the hood vent.
I think the C7 Z06 comes stock with some hood vents, right? Do you guys have an engine shroud/plastic cover around the engine? If so, pull it off when on the track and see if it helps. It certainly won't hurt anything.
That would be a cheap way to see if there would be any gain from installing vents in the hood.
#1624
Sure.
They have been running porsche's for several years and recently built this car and will be racing in the trans am series. They are local to me and a bunch of good guys.
http://gotransam.com/news/index.cfm?cid=62165
Nice.....thank you.....good info!
#1626
Nice to see this thread get back on track and evolve into a productive discussion instead of the usual chest pounding and name calling. Lots of good info here that is very informative.
Thanks all.
Thanks all.
#1627
No blower cover or shroud on the Z06. The only hood vent is the partial exit for radiator airflow. Wonder if propping the hood open ~ an inch or so would help engine compartment cooling without a great impact on aero? You could seal the radiator to hood vent gap with a piece of foam.
I still need to swap out my radiator fluid for distilled water/water wetter. I live in TX and won't ever drive the car when it's cold out, so should be good for me and it is supposed to help noticeably with the heat dissipating ability of the cooling system.
#1628
And if indeed it is a Trans Am car, it is probably more like 2500 pounds and tube frame, with a normally aspirated engine. I'm afraid it probably has no relevance at all to the C7Z06
#1629
my friend has 2 of them. They are quite a few out there now. He placed 4th at daytona. But feels the car is indeed a winner this year. And this is coming from a guy that has raced Porsche's for years.
#1630
If he is running Trans Am there are no Porsches. Exactly what class and series is this car running?
#1631
Yeah, that was one of tide them thar rhetorical questions. Makes my point that race cars aren't FI unless forced to do so like F1.
A good analogy specific to the C7Z as a track car is like new track guys looking for an alignment or brake pads or tires that work well on street and track. This unicorn does not exist.
#1632
Perhaps the mightiest road racer ever to come to US was the Porsche 917/30. There were no rules restricting power plants and displacement in Can Am in the early 70s. The 917/30 CRUSHED the big block chevy powered cars.
#1634
looks like I will be running road atlanta this saturday. Got a invite from my friends over at MTI racing. Anyone else interested go to http://tracksunlimited.net/
Hope to see some of you out there. 49* and partly cloudy.
#1635
This was the news release from this past daytona event with the corvette.
http://www.prnewswire.com/news-relea...-283328871.htm
#1636
Seems like there are quite a few folks who have tracked there cars here. If you have tracked your car at more than one track and have a PDR can you take a look at this: https://www.corvetteforum.com/forums...rt-marker.html
#1637
CorvetteForum Editor
Tadge Juechter Responds to the C7 Corvette Z06's Overheating Issue
Corvette Forum has asked Tadge Juechter about the C7 Z06's tendency to overheat after a bit of flogging. See Juechter's answer after the jump.
Read the rest on the Corvette Forum homepage. >>
#1638
Great Pic!
#1639
If the Chevrolet design staff had thought things out properly, they would have left room in the engine compartment for a twin-turbo V8, and we wouldn't be having all this talk about supercharger issues for a track car.
#1640
It's not just F1. All of the high end LeMans prototype cars are turbocharged, including the newest entry by Nissan. And for road cars, you have turbos on the new Ferrari 488, all the McLarens, the GT-R, the upcoming Ford GT and NSX, the new Mercedes AMG GT, and the rumour is that all future Porsches will be turbocharged, not to mention the new super hybrid cars and BMW's and other Mercedes cars, etc.
Bish
